Removing Paint Off of Brakes/Calipers
The previous owner applied paint on the brakes and so I am planning to use Aircraft Paint Stripper. However, if I apply this solution with the brakes still on the rotor, will it cause anything to rust? Also, will the brake hoses/lines deteriorate over time? Thanks.
i just took mine to a track event and cooked the brakes!
i think the easiest solution for you would be to get a can of flat black, and spray over the paint.
i wouldnt use stripper on a caliper that wasnt disassembled, it could eat into the dust shield for the piston, eat the line, and cause you to die in a fire.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman »</TD></TR><TR><TD CLASS="quote">I vote for burning the paint off at the track!</TD></TR></TABLE>
Yup, that is what I have been in the process of doing. Then again...I could careless what they look like as long as they stop me quickly.
