Suspension & Brakes Theory, alignment, spring rates....
Bushing: Shock Fork Mount --> How's it work?
Old Sep 12, 2006 | 08:26 PM
Trickturn's Avatar
Default Bushing: Shock Fork Mount --> How's it work?
I checked the shape of the bushings on my EG. I picked up this car not too long ago & want it as a drag strip/road race car. Replace the bushings high on the list.
Most of the bushings were ok, so I won't touch them until I have more track time w/ the car. I wanted to see which bushings NEEDED replacing now.
What I noticed:
Rear
- Lower control arm bushings ok, not the best, but ok
- Upper control arm bushings on the arm end ok; on the body end they NEED replacing
- The shock mount bushings on the lower control arm NEED replacing. Very cracked
Front
- A Arm bushings ok
- All balljoint bushings ok
- Shock mount bushings NEED replacing. Very cracked
As I noticed & you read, the front & rear shock mount bushings were very cracked & needed replacing. Why would those crack the most?
I don't understand how that point gets a lot of stress as the body is on one end of the LCA & the rotor assembly on the other side should keep it stable... right? How are they supposed to work? Up & down w/ the shock? Or back & forth w/ the A arm? Both?
- What other stress points should I look out for or replace for what I plan on doing w/ the car?
Thank you for all your answers.
Old Sep 13, 2006 | 04:48 AM
EnjoyTheRideDC2's Avatar
Default Re: Bushing: Shock Fork Mount --> How's it work? (Trickturn)
The Shock fork mount bushings become worn and cracked so easily because they take the most abuse in regards to wear and tear + weather conditions. They are often neglected when it comes to lubrication and care.
Under load, as the control arm travels upward, the shock/spring assembly is being compressed. As the shock rebounds and extends outward again, it pushes against the control arm. That pushing and pulling motion at the shock fork is a lot of stress for a rubber bushing to handle. This is from what I have been told.
Trunks31415
Dec 6, 2015 02:07 PM
blk_dc
Suspension & Brakes
Aug 3, 2011 08:11 AM
cheap2
Suspension & Brakes
23
Apr 17, 2010 07:29 PM
DavidR
101
Jul 6, 2009 09:22 PM
92integraVTECgsr
Suspension & Brakes
Oct 3, 2007 10:01 PM
