bad coil? car starts now but is powerless
UPDATE: Changed the spark plugs, and plug wires tonight and she fires right up with no hesitation or missing. The only problem now is it seems to have a high idle around 1500....on a cold start the idle is like 2k...tapping the gas makes the idle go down to 1000 and then it raised back to 1500 rpsms? what gives? ignition timing is perfect.
97 ek with d16b7, car broke down on me tonight, something popped and it died pretty instatnly. no cel's, would not start after it quit just would turn over and over and smoke was coming from the intake. I replaced the coil with that of a distributor king obd1 coil and the car starts up fine now but idles rough and is powerless, seems to be running on 3 cylinders maybe? throwing code 45... any thoughts on this? i'll know a bit more tomorrow in the daylight....
Modified by crexer at 10:51 PM 9/13/2006
Modified by crexer at 6:39 PM 9/14/2006
Well, Code 45 usually resorts ot hte O2 sensor. But before you check any of that, check your spark plugs. And I am pretty sure you shoul have an obd2 Coil. Not sure if that has anything to so with it.
ok im gonna throw in some new spark plugs, and try the ignitor, does anyone know for sure if the obd1 and obd2 coils are perform same? they look identical...
bay.kid
Sep 24, 2017 09:46 AM
