2000 civic ex stops in the middle of traffic....help!
Old Sep 12, 2006 | 05:27 PM
sam385's Avatar
Default 2000 civic ex stops in the middle of traffic....help!
2000 civic ex just stopped...sounded like itwas running out of gas. we checked fuel pump, filter, checked for spark, connected OBD2 tester. no codes. tester says ecu is aok. have fuel and spark. wtf is going on here? we are stumpped!
Old Sep 12, 2006 | 05:40 PM
Miracle's Avatar
Default Re: 2000 civic ex stops in the middle of traffic....help! (sam385)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sam385 &raquo;</TD></TR><TR><TD CLASS="quote">2000 civic ex just stopped...sounded like itwas running out of gas. </TD></TR></TABLE>
*SMARTASS COMMENT* Was there gas in the tank? /smartass comment.
Other than that, I am stumped. If it isn't throwing a code, Im not sure what it could be... Would like to find out though.
Old Sep 12, 2006 | 07:15 PM
sam385's Avatar
Default Re: 2000 civic ex stops in the middle of traffic....help! (.Red.EM2)
yes. i asked the same thing. i wish it were something that simple!
Old Sep 12, 2006 | 07:20 PM
Luserkid's Avatar
Well how sure are you that there was gas in there? Just cause the needle says so doesnt mean its true. Whats the car doing when you try to start it?
Old Sep 12, 2006 | 07:25 PM
4dohs4mohoes's Avatar
Default Re: 2000 civic ex stops in the middle of traffic....help! (Luserkid)
How did you check the fuel pump? And did you listen to the mail relay to hear if it clicked? Check the main relay.
Old Sep 12, 2006 | 07:31 PM
EL Vap133's Avatar
How many miles does it have, when was the last time the timing belt was replaced?
Old Sep 12, 2006 | 07:32 PM
Miracle's Avatar
Default Re: 2000 civic ex stops in the middle of traffic....help! (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">How many miles does it have, when was the last time the timing belt was replaced? </TD></TR></TABLE>
Wouldn't a snapped timing belt throw a code due to the timing sensors going haywire due to the disorientation of the crank and cams?
Old Sep 12, 2006 | 07:50 PM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Red.EM2 &raquo;</TD></TR><TR><TD CLASS="quote">Wouldn't a snapped timing belt throw a code due to the timing sensors going haywire due to the disorientation of the crank and cams?</TD></TR></TABLE>
Nope, car will shut off and show no signs.
Old Sep 12, 2006 | 08:21 PM
EL Vap133's Avatar
Nope, it didn't throw a code on my Teg when it happened. Luckily I had it towed and did not attempt to start it and the we discovered the problem.
Old Sep 13, 2006 | 05:45 AM
sam385's Avatar
i did hear the main relay click and the fuel pump is running. gas sprays out when i loosen the banjo bolt on top of the fuel filter. the car has 110,000 miles and was recently (6 months ago) purchased from a reputable honda dealer. we are going to look at the timing belt next. will let y'all know what we find. gosh! i'm glad CRX isn't this big of a pain-in-the-***!
Old Sep 13, 2006 | 11:26 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sam385 &raquo;</TD></TR><TR><TD CLASS="quote">i did hear the main relay click and the fuel pump is running. gas sprays out when i loosen the banjo bolt on top of the fuel filter. the car has 110,000 miles and was recently (6 months ago) purchased from a reputable honda dealer. we are going to look at the timing belt next. will let y'all know what we find. gosh! i'm glad CRX isn't this big of a pain-in-the-***! </TD></TR></TABLE>
CRX's have timing belts too.
Bgonz1993
Feb 3, 2015 03:08 PM
cwb314
Jan 23, 2015 03:15 PM
Brewbot87
May 6, 2013 07:15 PM
Andrewzabomb
Jul 4, 2011 01:40 PM
