2000 civic ex stops in the middle of traffic....help!
2000 civic ex just stopped...sounded like itwas running out of gas. we checked fuel pump, filter, checked for spark, connected OBD2 tester. no codes. tester says ecu is aok. have fuel and spark. wtf is going on here? we are stumpped!
Re: 2000 civic ex stops in the middle of traffic....help! (sam385)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sam385 »</TD></TR><TR><TD CLASS="quote">2000 civic ex just stopped...sounded like itwas running out of gas. </TD></TR></TABLE>
*SMARTASS COMMENT* Was there gas in the tank? /smartass comment.
Other than that, I am stumped. If it isn't throwing a code, Im not sure what it could be... Would like to find out though.
Well how sure are you that there was gas in there? Just cause the needle says so doesnt mean its true. Whats the car doing when you try to start it?
Re: 2000 civic ex stops in the middle of traffic....help! (Luserkid)
How did you check the fuel pump? And did you listen to the mail relay to hear if it clicked? Check the main relay.
Re: 2000 civic ex stops in the middle of traffic....help! (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">How many miles does it have, when was the last time the timing belt was replaced? </TD></TR></TABLE>
Wouldn't a snapped timing belt throw a code due to the timing sensors going haywire due to the disorientation of the crank and cams?
Re: 2000 civic ex stops in the middle of traffic....help! (.Red.EM2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Red.EM2 »</TD></TR><TR><TD CLASS="quote">Wouldn't a snapped timing belt throw a code due to the timing sensors going haywire due to the disorientation of the crank and cams?</TD></TR></TABLE>
Nope, car will shut off and show no signs.
Nope, it didn't throw a code on my Teg when it happened. Luckily I had it towed and did not attempt to start it and the we discovered the problem.
i did hear the main relay click and the fuel pump is running. gas sprays out when i loosen the banjo bolt on top of the fuel filter. the car has 110,000 miles and was recently (6 months ago) purchased from a reputable honda dealer. we are going to look at the timing belt next. will let y'all know what we find. gosh! i'm glad CRX isn't this big of a pain-in-the-***!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sam385 »</TD></TR><TR><TD CLASS="quote">i did hear the main relay click and the fuel pump is running. gas sprays out when i loosen the banjo bolt on top of the fuel filter. the car has 110,000 miles and was recently (6 months ago) purchased from a reputable honda dealer. we are going to look at the timing belt next. will let y'all know what we find. gosh! i'm glad CRX isn't this big of a pain-in-the-***! </TD></TR></TABLE>
CRX's have timing belts too.
Andrewzabomb
07-04-2011 01:40 PM
