Is it possible to mix up the plugs on ur fuel injectors?
Old Sep 12, 2006 | 04:57 PM
Si_chRis's Avatar
Default Is it possible to mix up the plugs on ur fuel injectors?
Like the title said and if u do mix them up, does it affect anything?
Old Sep 12, 2006 | 04:59 PM
Miracle's Avatar
Default Re: Is it possible to mix up the plugs on ur fuel injectors? (EM1_ChRiS)
It would mess something up, because if a harness meant for the #4 cylinder is on the #3 cylinder, the injection timing will be off.
But I'm not sure if they would be long enough to reach the next cylinder... At least they are not on mine.
Old Sep 12, 2006 | 05:00 PM
Si_chRis's Avatar
Default Re: Is it possible to mix up the plugs on ur fuel injectors? (.Red.EM2)
so u would definately notice somthing and ur car would run poorly right?
Old Sep 12, 2006 | 05:02 PM
Miracle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1_ChRiS &raquo;</TD></TR><TR><TD CLASS="quote">so u would definately notice somthing and ur car would run poorly right?</TD></TR></TABLE>
If the injectors are dumping when they are not supposed to, I would assume common sense would tell you it would run a little rough, if at all.
Old Sep 12, 2006 | 05:06 PM
Si_chRis's Avatar
but for the most part like on my car (i have the stock fuel hardware on my 2000 si), the wires would only be the correct length for that certain injector and most likely not possible to mix them up?
Old Sep 12, 2006 | 05:15 PM
Miracle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EM1_ChRiS &raquo;</TD></TR><TR><TD CLASS="quote">but for the most part like on my car (i have the stock fuel hardware on my 2000 si), the wires would only be the correct length for that certain injector and most likely not possible to mix them up?</TD></TR></TABLE>
There again, common sense would say that the harnesses would only be long enough for their respective injectors.
What is the car doing?
Old Sep 12, 2006 | 06:13 PM
jdmeg9's Avatar
that would take some talent to get them mixed up
Old Sep 12, 2006 | 06:41 PM
clemsonteg's Avatar
i actually dont think it matters, think about when people put dsm injectors in their cars with the resistor box, you take the 8 wires total for the 4 injectors, 4 of the wires go to indiviual wires on the box( doesnt matter which one) and 4 of them go to 1 commom power. thats just my thoughts though
Old Sep 12, 2006 | 07:14 PM
Luserkid's Avatar
Default Re: Is it possible to mix up the plugs on ur fuel injectors? (clemsonteg)
The power source doesnt matter but the signal matters very much so. If you have them mixed up the car shouldnt start (although if you only mix up one set then it might start but run like *** if at all).
Crank
Brown (injector 1)
Red (injector 2)
Blue (injector 3)
Yellow (injector 4)
Flywheel/transmission
Old Sep 12, 2006 | 07:32 PM
clemsonteg's Avatar
yeah i can see that you are correct on that one, i forgot that the power is the only thing that is spliced on that side, that the other for go straight to the ecu
Old Sep 12, 2006 | 08:02 PM
Si_chRis's Avatar
no, nothings wrong with my car, it doesn't act funny. The idea just popped into my head because i did a compression test and i unplugged the injectors. Then that though came to me but yea, nothings wrong with my car.
Rheg6
Nov 24, 2011 08:46 AM
TurboTeG4
Aug 21, 2010 08:57 PM
OrangeBoost
May 30, 2006 10:22 AM
magic hat #9
Sep 19, 2003 08:23 AM
g5r
Sep 4, 2003 06:04 AM
