LS crank/rods RELIABILITY in GSR bottom end
Old Sep 12, 2006 | 04:01 PM
RHDintegXsi's Avatar
Default LS crank/rods RELIABILITY in GSR bottom end
if one were to swap the crank/rods from an ls into a gsr bottom end would it...
affect reliabiltiy?
be able to safely rev to 8200rpm?
require any modification to the block? (clear oil squiters etc..)
lastely..would the gains be worth the extra work?
Old Sep 12, 2006 | 04:09 PM
Brice.Hayden's Avatar
Default Re: LS crank/rods RELIABILITY in GSR bottom end (SINFULintegXsi)
Should I assume you're using ARP rod bolts or would you be useing OEM rod bolts?
I'm not sure what gains you are expecting to see over a gsr crank?
Old Sep 12, 2006 | 10:04 PM
Default Re: LS crank/rods RELIABILITY in GSR bottom end (JasperDA9)
right now im just "reasearching", IF the gains arent worth the work i most likely wont even consider it
Old Sep 12, 2006 | 10:31 PM
hayabusa160's Avatar
i like the low end the ls crank gives.
i have arp rod bolts in mines and jdm itr pistions. 200whp 140 torque
Old Sep 13, 2006 | 09:20 AM
Default Re: LS crank/rods RELIABILITY in GSR bottom end (hayabusa160)
those are nice numbers..whats your setup? if you dont mind me asking.
in your opinion do you think it was worth it to run the ls crank over a gsr one?
Old Sep 13, 2006 | 09:04 PM
ported gsr head aebs intake manifold profab header,
bored out gsr tb
skunk2 stage2s with skunk2 valvetrain
ls crank and rods jdm itr pistons
i guess its worth it you wont get this kinda of torque with a gsr.
heres my dyno
http://www.we-todd-did-racing....D.jpg
Old Sep 14, 2006 | 06:00 AM
pomansouth01's Avatar
Ginger Kid
what does it make on a dynojet??
Old Sep 14, 2006 | 07:50 AM
efi2nr's Avatar
From: Home of the fastest Hondas in the 417 area since, 1997, usa
Default Re: (pomansouth01)
we do them all the time, its a great upgrade for a GSR block just make sure you get the right pistons
elbotygsr
Feb 8, 2011 07:36 PM
spap3
Apr 7, 2010 12:45 PM
leroyb
May 6, 2009 07:13 PM
swapped95
Aug 18, 2007 06:51 PM
jdmsijdm
Dec 19, 2004 10:53 AM
