bleeding the clutch
Old Apr 29, 2002 | 03:38 PM
Toda Party's Avatar
Default bleeding the clutch
I've got some brake fluid left over from flushing my brakes theother day and i figured i'd do the clutch slave cylinder since i have the spare fluid..apparently its similiar to the brakes?
i was looking at the slave cylinder, and i'm trying to figure out how to do it. one member was kind enough to explain it to me, but he described it as using a vaccum pump, which i wont have.
can someone perhaps post a pic and elaborate on this procedure? TIA
Old Apr 29, 2002 | 03:51 PM
Eric R's Avatar
Default Re: bleeding the clutch (Toda Party)
You can use the same fluid as in your brake lines.
If you don't have a vacuum pump, use the good old method of pumping the pedal.
Tell a friend to help you out in this task, and watch for the tank level. It empties very fast.
Good luck!
Eric - who was that guy...
[Modified by '01ITR#950, 4:52 PM 4/29/2002]
Old Apr 29, 2002 | 04:21 PM
B2FiNiTY's Avatar
Default Re: bleeding the clutch ('01ITR#950)
How often should you change it?
Old Apr 29, 2002 | 04:38 PM
Toda Party's Avatar
Default Re: bleeding the clutch (OdysseyTypeR)
here's the procedure for anyone else who was wondering, thanks to eric
Using the pedal, the procedure is as follows:
1) Open the tank lid.
2) Have someone to depress the clutch pedal and hold it down.
3) Connect a small clear hose that fits the bleeding nipple and then into a container (like a Gatorade bottle).
4) With an 8mm wrench, losen the bleeder slowly and wait until the old fluid go out.
5) Close the bleeder, still keeping the pedal depressed. After closed, tell your pal to release the pedal. Do not release the pedal with the bleeder open so air will get in the system!
6) Repeat the whole steps before. Add fluid if too low.
You should stop the process when you see new fluid (clear) coming out the bleeder. Refill the tank up to its normal level and cap it off. Clean with water any fluid spillage. That's it.
Old Apr 29, 2002 | 05:01 PM
sackdz's Avatar
I know there is some talk about how ATE fluid is harmful to the seals of the brake system. I also think there was one of two people who used it in their clutch as well. Has anyone had any problems?
Old Apr 29, 2002 | 05:02 PM
onyx00's Avatar
Default Re: bleeding the clutch (sackdz)
I've been suing ATE for about a year now and no problems as of yet. Who did you hear this from?
Old Apr 29, 2002 | 05:03 PM
sackdz's Avatar
Default Re: bleeding the clutch (onyx00)
Here and there. I recall something to the extent of ATE being alright but when you switch to a different fluid it can cause problems, the seals swell and such.
Who knows the dealio?
Old Apr 29, 2002 | 06:46 PM
bus stop's Avatar
NOT ture......I use ATE for my brake and clutch, no problem.
Todd00
Jan 23, 2010 05:23 PM
JDMInspired
Honda Civic (2001 - 2005)
10
May 6, 2009 11:05 PM
Mr. Eric
Nov 18, 2008 09:30 AM
autoxthis
Aug 21, 2008 08:56 PM
91civicmoneypit
18
Apr 14, 2004 03:41 PM
