Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
205/55/16 (Stock) or get 205/50/16? Need opions/advice plz!
Old Sep 12, 2006 | 02:09 PM
Declectic's Avatar
Default 205/55/16 (Stock) or get 205/50/16? Need opions/advice plz!
Hello all, the time will be coming soon that I will be needing new tires again. Not gonna get anything fancy because I commute 75 miles (total) each day. Currently still on the tires that came with my 2006 Civic EX (23,000, probably got another 8k miles left).
Stock OEM tires are 205/55/16. I've lowered my car on Tein s-techs (not dumped but rids of wheel gap - exact drop is suppose to be 1.4"F/1.3"R)
So i'm looking for experienced opions or advice
A - stick with 205/55/16
B - go with 205/50/16
C - if you recommend something different, throw it out there
So becuase I'm lowered, the tires look even bigger than before I lowered them, here is a few pics of before/afer
thanks guys!
Old Sep 12, 2006 | 07:43 PM
06civicracer's Avatar
Default Re: 205/55/16 (Stock) or get 205/50/16? Need opions/advice plz! (SeanJohn1802)
i think you should go with the 205/50/16,cause the oem one doesnt give that much space
Old Sep 12, 2006 | 08:22 PM
boostedlude97's Avatar
225-50...... FTW
Old Sep 13, 2006 | 12:29 AM
Declectic's Avatar
Default Re: 205/55/16 (boostedlude97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedlude97 &raquo;</TD></TR><TR><TD CLASS="quote">225-50...... FTW </TD></TR></TABLE>
I don't feel to confident that 225 would fit properly on stock 16x6.5 rims... show me some pics of that if you really feel that is an apropriate size
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 06civicracer &raquo;</TD></TR><TR><TD CLASS="quote">go with the 205/50/16,cause the oem one doesnt give that much space</TD></TR></TABLE>
what do you mean?
thanks for the responses
Old Sep 13, 2006 | 12:42 AM
SennaPerfected's Avatar
Default The proper upgrade from 205/55/16 (Stock) is 225/50-16
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SeanJohn1802 &raquo;</TD></TR><TR><TD CLASS="quote">Hello all, the time will be coming soon that I will be needing new tires again. Not gonna get anything fancy because I commute 75 miles (total) each day. Currently still on the tires that came with my 2006 Civic EX (23,000, probably got another 8k miles left).
Stock OEM tires are 205/55/16. So i'm looking for experienced opions or advice
C - if you recommend something different, throw it out there</TD></TR></TABLE>
SeanJohn1802: When changing tire width, even when keeping the same wheel size (as you are doing with your OEM 16 x 6.5), the goal is to properly maintain the overall diameter of the tire, thereby keeping the odometer and speedometer changes to a negligible margin, if any. By using a tire with a shorter sidewall, you gain quickness in steering response and better lateral stability, albeit with a more stiffer ride. The visual appeal is obvious as most wheels look better, so the more wheel and less sidewall there is, the better it looks. Having said that, to keep your speedometer and odometer accurate, your only other choice in 16" (as boostedlude97 has suggested) is 225/50-16. Your choices for 225/50-16 tires can be seen <FONT COLOR="blue">here</FONT>.
Keep in mind that the choices in the 225/50-16 tire size are characterized as either Extreme Performance Summer or Max Performance Summer. Your OEM tire is characterized as either High Performance All-Season or Standard Touring All-Season. A couple of things to consider: Your current commute and will changing from and all-season to summer tire be a factor?
The 205/50 and 215/45 sizes can only be used if you go with a plus one concept, which in this case, you would use a 17" x 7" wheel and either 205/50-17 or 215/45-17 tire.
Old Sep 13, 2006 | 12:58 AM
Declectic's Avatar
Default Re: The proper upgrade from 205/55/16 (Stock) is 225/50-16 (SennaPerfected)
thank you for the very elaborate reply! Very much appreciated
Think I may have to see if i can stretch the money to some 17's
Old Sep 13, 2006 | 01:13 AM
Default The proper upgrade from 205/55/16 is 225/50-16 or plus one 205/50-17 or 215/45-17
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SeanJohn1802 &raquo;</TD></TR><TR><TD CLASS="quote">thank you for the very elaborate reply! Very much appreciated </TD></TR></TABLE>
You're welcome...
Old Sep 13, 2006 | 03:29 PM
dpao6's Avatar
Default Re: The proper upgrade from 205/55/16 (SeanJohn1802)
sennaperfected preatty much said it all. Couldn't have explained it better. But keep one last thing in mind which is also quite important, and that is the load index of the tire. Usually when you go lower aspect ratio without increasing the width, the load index drops, which makes the tire unsafe for vehicles of certain weight class. To put that in plain english, I once had a EG Hatch that I tried to put 195/45-15 tires on the rims which should've had 195/50-15s, tirerack called me back and said, unless I owned a Geo Metro, that aspect ratio is simply too low even for a light-weight like the Eg hatchback.
more info here ...
http://www.tirerack.com/tires/...id=35
Old Sep 14, 2006 | 02:16 PM
Default Re: The proper upgrade from 205/55/16 (dpao6)
this weekend i'll be putting 225-50's on a set of EX wheels, so i'll try to get some pics
Old Sep 14, 2006 | 03:19 PM
Declectic's Avatar
Default Re: The proper upgrade from 205/55/16 (boostedlude97)
sweet man, post up as soon as you can, can't wait to see the pics
Old Sep 15, 2006 | 05:21 AM
i really can't believe i'm doing it, i did buy an SI that now looks more like an EX everyday........
Nordy
19
Aug 24, 2007 06:17 PM
StolenTeg
Northeast (Sales)
Apr 21, 2007 09:54 AM
Declectic
Sep 17, 2006 07:17 AM
Wrath of VTEC
Aug 26, 2001 11:39 PM
