1.5 dx distributor woes
Old Sep 12, 2006 | 01:53 PM
VeilSide_Mas's Avatar
Default 1.5 dx distributor woes
how do u guys check if a distributor is good or bad? my car been dying mysteriously with a code 15 but the ignitor and ecu are ok.. just that last time it used to leak oil from the distributor and i wonder if that made it bad.
every single help is appreciated
Old Sep 12, 2006 | 01:59 PM
rayzian's Avatar
Default Re: 1.5 dx distributor woes (VeilSide_Mas)
one way to check to remove it and open it up and see how smooth the rotor spins.. mine spins pretty un-smoothly and I've already had the car die on me at random times where all I hear is a *pop* and the car's suddenly off, i also forgot to mention my car stutters a little around 4krpm when the RPM needle starts to go crazy all over the place
Modified by rayzian at 3:18 PM 9/12/2006
Old Sep 12, 2006 | 05:45 PM
O_O . it's suppose to spin smooth? i can't move it with my hand with the distributor cap off. does that mean i have to replace the whole unit if i cant spin it?
Old Sep 12, 2006 | 06:42 PM
92integra_gs's Avatar
you got to remove it from the camshaft first...
remember rotor is connected to the camshaft and camshaft is connected to the timing belt which is connect to you know what... so its impossible to move it without removing it from the engine...
Old Sep 12, 2006 | 06:57 PM
oh , dang it ........ my bolt on the top of the distributor stripped.
any idea how to get a stripped bolt out from that position of the distributor?
Old Sep 12, 2006 | 07:06 PM
vise grip .. bro...
Old Sep 13, 2006 | 03:20 PM
i put the biggest vise grips i can find and clamped hard on it. it ate the bolt but it could not budge it.
any specific brand or type to look for ?
Old Sep 13, 2006 | 04:08 PM
E_F_9's Avatar
lefty loosey righty tighty
Old Sep 14, 2006 | 02:10 PM
errr i know the sequence to get it loose bro...
any good vice grips recommendation?
Old Sep 14, 2006 | 02:29 PM
rayzian's Avatar
Default Re: (VeilSide_Mas)
haha my top bolt got stripped too but vice grips gets them out.. just keep trying..
blacktibby07
11
Feb 5, 2011 03:12 PM
manyakiexpi
Mar 2, 2006 10:02 PM
Project_ED8
Mar 3, 2004 01:03 PM
