pedle assembly HELP!!!!
Old Sep 12, 2006 | 01:48 PM
EF-Honda91's Avatar
Default pedle assembly HELP!!!!
I'v looked around everywhere and i cant find anything on what im looking for so this is the problem
I'm working on my friends 89 civic hatch and i noticed when i put a clutch cable in there it still wasn't working right, so i got under there and noticed the round piece that extends from the clutch pedle to the break pedle is broke off thus making the clutch pedle when u push in push in diagonally and the metal piece under there is bent so i bent it back so now he wants the whole thing underthere reworked so i need to know somthing where i can take it all out individual piece on how to take the whole assembly out clutch, break, gas pedle out, if u know of a way where i can jut take the clutch assembly apart because it looks like two pieces but welded, someone please help me i need to fix this quickly please help
Old Sep 12, 2006 | 02:55 PM
theinfamouskonrad's Avatar
Default Re: pedle assembly HELP!!!! (EF-Honda91)
just take off the clutch pedal + gas pedal first... it's straight forward to disconnect them. Next drop your steering column (2 12mm nuts and 2 12mm bolts). Then take out the little cotter pin and actual pin that connects the brake pedal to the brake booster. After that just take off the (6) 12mm nuts and (1) 12mm bolt that will hold the bracket up on the top. Just maneuver it out afterwards.
Old Sep 12, 2006 | 02:56 PM
TrueNorthStar's Avatar
I don't know if the 88-89 pedals are the same as my 91 (don't see why not) but the clutch+brake+gas pedals are on one assmebly and its all welded together.
I don't recall if the clutch pedal can be un bolted byitself (I cut the clutch part off of mine), but the frame of the assembly cannot be dis-assembled by pedal. That I know for sure.
Old Sep 13, 2006 | 10:17 AM
EF-Honda91's Avatar
Ok, i have finally unbolted the break pedal to where when u push it in the screw threads go threw the holes, and now im having trouble unbolting the throttle cable off of the gas pedal at the top? and getting the break booster off? i am a novice at the stuff and this is my first time but im writing everything down as i take it apart so i know how to put it back together, i think im going to try to print this off so i can read while i do it, thank u very much for helping me out. i'l keep u posted on how its coming.
Old Sep 14, 2006 | 12:54 PM
EF-Honda91's Avatar
Ok, i have started to try to take the colum off and no luck, to me its over my skill level if someone can talk it over piece by piece i would be willing to try again, and next step i guess i can all ways get a Haynes Manual. thanks everyone who i guess the select few.
Old Sep 14, 2006 | 01:21 PM
SiMateoAko's Avatar
check it yo..
https://honda-tech.com/zerothre...02506
Old Sep 14, 2006 | 02:42 PM
EF-Honda91's Avatar
Man thank you so much for helping me out!! i'l go home right now and see what i can do.
EF-Honda91
Sep 12, 2006 11:13 AM
ivanson
Mar 16, 2005 11:03 PM
civic_sir94
Dec 1, 2002 10:42 AM
teamnvisible
Mar 22, 2002 09:24 PM
