whats the oil drain plug torque spec?
Old Sep 12, 2006 | 01:23 PM
BrianCivicDX's Avatar
Default whats the oil drain plug torque spec?
i have a 1995 civic dx with a 5 spd 1.5 L. does anyone know the torque spec for the oil drain plug?
Old Sep 12, 2006 | 01:27 PM
Lewy. Dee Ayy's Avatar
Default Re: whats the oil drain plug torque spec? (BrianCivicDX)
just make sure its snug.
Old Sep 12, 2006 | 01:29 PM
EX-T's Avatar
You going to put a torque wrench on it everytime you change the oil? Just tighten it until you feel the crush washer 'crush'!?!
Old Sep 12, 2006 | 01:30 PM
BuGeorge428's Avatar
lol, you dont need to torque it
Just use common sense and tighten it till its on....whats the word im lookin for...tightly, lol. Dont go cranking it down and screwing up your threads.
What i like to do is screw it on with my fingers till its all the way in, then take the ratchet and tighten it till it gets hard to turn without excessive force.
If you still cant get it, i dont know how else to help you ...
Old Sep 12, 2006 | 02:16 PM
excivicboy96's Avatar
Default Re: whats the oil drain plug torque spec? (BuGeorge428)
dont strain your self putting it on or else it will be a **** getting off next time you need to get it off.
Old Sep 12, 2006 | 02:18 PM
Jorsher's Avatar
turn it until it's tight
Old Sep 12, 2006 | 02:55 PM
eg:R's Avatar
i think it is 32lbs.
Old Sep 12, 2006 | 03:11 PM
EG2Driver's Avatar
Default Re: (eg:R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg:R &raquo;</TD></TR><TR><TD CLASS="quote">i think it is 32lbs. </TD></TR></TABLE>
its in the 30s, i know that much for sure, but 32 sounds about right.
Old Sep 12, 2006 | 03:35 PM
MonkeyBoy668's Avatar
Default Re: whats the oil drain plug torque spec? (EX-T)
On 96-97 Del Sols it's 45Nm, or 33ft-lbs.
I use my torque wrench on everything that Helms shows a torque value for.
Old Sep 12, 2006 | 03:51 PM
EgSalad's Avatar
Default Re: whats the oil drain plug torque spec? (MonkeyBoy668)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MonkeyBoy668 &raquo;</TD></TR><TR><TD CLASS="quote">On 96-97 Del Sols it's 45Nm, or 33ft-lbs.
same goes for all model 92-95 Civic's. 33ft-lbs.
Old Sep 12, 2006 | 08:18 PM
nighttrain33's Avatar
I think that 30 lb/ft should be sufficient, but I don't know anybody that actually uses a torque wrench for the drain plug. Not to say that it's wrong to, but just not neccessary. My manual has 29 lb/ft for d16y5 & d16y8, and 33lb/ft for d16y7, so as I already said, 30 lb/ft should be good (though I know you have the 1.5).
-Shane
Old Sep 12, 2006 | 08:39 PM
SovXietday's Avatar
Default Re: whats the oil drain plug torque spec? (nighttrain33)
Y8 has an aluminum pan, the threads are easier to strip.
Everything else (dseries wise) is steel, so you can give it a bit more torque.
IMO, just torque it till it's tight, it's really not worth pulling out a torque wrench for.
Old Sep 12, 2006 | 08:56 PM
Default Re: whats the oil drain plug torque spec? (SovXietday)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SovXietday &raquo;</TD></TR><TR><TD CLASS="quote">IMO, just torque it till it's tight, it's really not worth pulling out a torque wrench for.</TD></TR></TABLE>
Exactly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SovXietday &raquo;</TD></TR><TR><TD CLASS="quote">Y8 has an aluminum pan, the threads are easier to strip.</TD></TR></TABLE>
Even though the block is the same, they switched oil pans with the y8's? That's kinda wierd. Any clue why?
-Shane
Old Oct 18, 2015 | 08:19 AM
andyrulz's Avatar
30 ft lbs if it's a steel pan . I know I work at honda and I own a 95 civic lx.
Aluminum is 29 ft lbs. Hope that helps
Old Oct 18, 2015 | 11:26 AM
NotARaCist's Avatar
I never narc'd on nobody!
So glad you could bump a 9 year old thread. Please don't do that. Ever. For any reason.
DannyDeuce
Feb 17, 2006 01:21 PM
RedGSR
Jun 6, 2005 03:07 AM
Chris y0!
Jan 16, 2003 11:36 PM
Mr Ludecrs
Jun 6, 2001 12:30 PM
