D16Z6 Swap with tach reading wrong. No CEL and running well. ::confused::
Old Sep 12, 2006 | 01:22 PM
eumoria's Avatar
Default D16Z6 Swap with tach reading wrong. No CEL and running well. ::confused::
I recently finished a D16Z6 swap on a friend's 91 CRX Si. With an O2 sensor replacement the engine is giving no codes, and seems to pull wonderfully. However, the tach (when at idle) now sits at 0 on the pin and as you accelerate it seems to be off as well.
What would cause the tach to read wrong without throwing a code, disabling vtec, or anything else? The tach was working fine with the D16A6 and it wasn't touched throughout the entire swap. Now, I have yet to test another cluster on it but only because I don't have one handy.
Anyone know what this could be? Is it most likely the cluster itself or is there something sensor/motor/ecu related?
Thanks.
Oh, and also I'm not 100% sure that vtec is engaging but I also can't read what RPMs I'm at... I pushed it up to 5k on the tach (my guess somewhere in the mid 6's for real) and I got no bogging or CEL although I couldn't detect an obvious change in power. It may be just working fine.
::confused:: Thanks again to any help.
Old Sep 12, 2006 | 02:16 PM
doublethink's Avatar
Default Re: D16Z6 Swap with tach reading wrong. No CEL and running well. ::confused:: (eumoria)
up for my bro
Old Sep 12, 2006 | 02:52 PM
nuckingfuts's Avatar
Default Re: D16Z6 Swap with tach reading wrong. No CEL and running well. ::confused:: (doublethink)
check the vehicle speed sensor and what tranny are you using???
Old Sep 12, 2006 | 03:22 PM
user 98292739's Avatar
wait your tach is reading wrong so you cant read your RPMS? thats usually a dizzy problem i think
now if you speedo was reading wrong then it might be your VSS
Old Sep 12, 2006 | 03:33 PM
Boosted Chemist's Avatar
Default Re: (The Lobster)
my money is on dizzy it creates the signal
Old Sep 12, 2006 | 06:18 PM
iphatcrxi's Avatar
Default Re: (Boosted Chemist)
my tach bounced around when the bolts on my dizzy were loose
Old Sep 13, 2006 | 01:39 AM
crxdriver1991's Avatar
i had the same problem and it was the dizzy
Old Sep 13, 2006 | 06:02 AM
eumoria's Avatar
hmm so maybe looking at the dizzy :/
i got the wiring from Rywire.com so i trust it. i'll doublecheck the connections/bolts/etc and see how it goes.
thanks again
Old Sep 13, 2006 | 06:45 PM
ahh your tachometer for some reason i was thinking what i wanted it to be good catch
PS..
what holds the motor in place?? i cant think for **** get at me
Old Sep 13, 2006 | 07:55 PM
wiZCo's Avatar
Stouts 'n' Scotch
Check the ignitor in your dizzy.
Draven8795
Feb 14, 2012 03:49 PM
scamp91ex
Nov 8, 2009 08:02 PM
luderich_kid
May 22, 2008 03:57 PM
stealth89hatch
13
Jun 17, 2005 03:25 PM
