I need more electrical power
Old Sep 12, 2006 | 12:05 PM
mnizzy's Avatar
Default I need more electrical power
I have a '92 Accord LX coupe and have a pretty decent sound system set up. My current battery is a POS, that part is clear and i know itll be replaced.
But what i want to know is if it would be a good idea to replace the alternator with something a little more powerful. I have an a mono amp sending 800 watts continuously to two subs in the trunk, and im gonna possibly run a 4 channel to some new speakers im gonna install.
No doubt this will take a good amount of power, that i doubt my car can handle, soo....
What do u guys advise.
Old Sep 12, 2006 | 12:28 PM
Hcivic88's Avatar
Default Re: I need more electrical power (mnizzy)
well like you said upgrading the alternator will be the most beneficial thing for you to do to save your charging system from overworking. your current alternator i believe is only about 80amps to begin with, which isnt bad but with a bigger system you still may want to upgrade.
a capacitor may also be a good idea for you too to save your battery from the voltage spikes(which make your lights dim when the amp draws a lot of power for a big hit).
i think you may get most of your answers in the audio/security forum though, you may have better luck over there.
Old Sep 12, 2006 | 01:26 PM
Perfectionist's Avatar
BTW, in case you're into speed too, 750 watts equals one horsepower.
Yes, a higher output alternator would help. A capacitor needs to draw power to recharge, it just helps to even out peak loads. It's all a balance between the battery and charging system.
Old Sep 12, 2006 | 03:13 PM
fcm's Avatar
fcm
Old Fart
94<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mnizzy &raquo;</TD></TR><TR><TD CLASS="quote"> I have an a mono amp sending 800 watts continuously to two subs in the trunk, </TD></TR></TABLE> Music is "dynamic" so your amp is not sending 800W "continuously" to the subs, however, it takes about 125A to make 800W RMS, [depending on what type of amp you have] I always recommend upgrading the alt. when total RMS wattage is 500W or more, a good batt. and a cap will also help, but it's the alt. that makes the power, so as has been mentioned do the alt. upgrade, it is worth it. 94
Old Sep 12, 2006 | 03:48 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: I need more electrical power (fcm)
make sure you do the big three to help out.
Old Sep 12, 2006 | 04:43 PM
mnizzy's Avatar
Thanks for the help and I know its not continous, i know my way around car audio , i was more just wondering how powerful an amp to get and what i should expect to pay
Once again thanks for the help guys!!!
Old Sep 12, 2006 | 05:08 PM
mnizzy's Avatar
After thinking about it im gonna wait to look into alternators after i see what kinda difference a new battery and the big three make
komodomoe
Audio / Security / Video
May 12, 2013 07:41 PM
allentownrep
14
Sep 17, 2009 11:22 AM
mnizzy
Sep 12, 2006 02:01 PM
SD1222
May 11, 2006 06:45 PM
h92
Mar 18, 2004 06:59 PM
