stupid suspension question
Old Sep 12, 2006 | 11:37 AM
B6tizzleHatch's Avatar
Default stupid suspension question
ok so i have progress springs that im putting on tokico illuminas.
since there just springs i need to compress them to put them on, well the spring compressor i have from autozone wont work, the "hook" (i guess you would call it) is to big and wont fit between the coils, and its to short to do it from the bottom and top, i also thried there coil spring compressor that goes on the inside of the spring, but again it was to big and wouldnt fit in the middle. so any ideas?
im not a suspension noob, ive done mulitpy suspension setups helping out friends and on my past cars etc, but ive never had this problem?
heeeelp me please!
Old Sep 12, 2006 | 11:53 AM
Tyson's Avatar
Default Re: stupid suspension question (B6tizzleHatch)
you should be able to install the progress springs with just your own weight. have a friend help you. the rears you should have absolutely no problem with.
this is NOT going to be true trying to put STOCK front springs on.
dont forget to clock the top hat properly before putting the nut on.
Old Sep 12, 2006 | 01:41 PM
EL Vap133's Avatar
That's weird, I didn't have to use a spring compressor to install my Tokico Illuminas using my Progress lowering springs.
Old Sep 12, 2006 | 06:41 PM
Default Re: stupid suspension question (EL Vap133)
im having s shop use ther compressor machine, and put them on the struts, only gonna cost 10 bucks, the ill put em on, that saves me a hassal. whats this about clocking before puttint the nut on? it didnt say anything about this is the instructions
MotoCARR
Suspension & Brakes
13
Oct 23, 2014 02:59 PM
DC5mike
Dec 11, 2008 01:05 PM
teknikEG6
13
Jan 13, 2006 01:29 PM
GZERO
Oct 6, 2002 06:16 PM
