calibration
if you look at that you'll see i've already been there, the guy i was talking to set me up with a calibration but it just seems a little off, then i found out it started life as a GSR base. just wondered if anybody had anything lying around on the hard drive like a standard H22 map or slightly tweaked one that they could let me see
it doesn't have p13 in the calib folder, do any of you guys have the accord/prelude base map, i must have an older version of smanager or sumthing because the only thing i have for a prelude is one that is for a JDM H22a running 450's and i dont trust it because my motor came with 290's to begin with. anyone help me out?
i could do that but it would probably still be wrong, the stock injector size is set to 310 or sumthing and then it says current injector size 450 so it multiplies it itself, i would think there are some key differences that would be different between the JDM h22 and my 5th gen. i wanted to get stock timing and stock fuel maps so that i could work from there
92JDMSiR
May 31, 2003 08:18 PM
