14" tire size...(del sol Si wheels)
Old Sep 12, 2006 | 11:18 AM
EFstyle's Avatar
Default 14" tire size...(del sol Si wheels)
I'm getting del sol Si wheels for super cheap and im going to need to replace 2 of the tires. I was just woundering how wide you could go on these wheels because I will be puting these 2 on the front.
Old Sep 12, 2006 | 11:41 AM
EFstyle's Avatar
Default Re: 14" tire size...(del sol Si wheels) (EKEJ6)
Bump
Old Sep 12, 2006 | 12:07 PM
bpwrdeg's Avatar
I fit 195/60/14 on a set of 14 inch steelies, im sure you can do the same, if not wider
Old Sep 12, 2006 | 12:08 PM
instructor74's Avatar
I know the stock tire size was 185 60 H14 for that wheel. If I remember correctly the honda 14 inch wheel is 6" wide where most aftermarket wheels in 14" are 7 " wide. I think you are as wide a the stock wheel can fit. Someone correct me if I am wrong
Modified by instructor74 at 1:47 PM 9/12/2006
Old Sep 12, 2006 | 12:29 PM
BiffStroganoffsky's Avatar
For the Si model the stock tire is a P185/60R 14 (22.7 inches around)
For the VTEC model the stock tire is a P195/60R 14 (23.2 inches around)
What engine and speed cluster are you using?
Old Sep 12, 2006 | 12:43 PM
SHG_Beans's Avatar
I don't think i'd go wider than 195's on 14in oem wheels. just my opinion.
belairbrian
Mar 6, 2015 07:06 AM
SomeGoodBud2
Feb 14, 2007 01:55 AM
Yellow Dragon
Mar 13, 2003 12:20 PM
keebler65
Dec 15, 2002 10:51 AM
VTEC KILLA
Dec 14, 2001 04:18 PM
