14" tire size...(del sol Si wheels)
I'm getting del sol Si wheels for super cheap and im going to need to replace 2 of the tires. I was just woundering how wide you could go on these wheels because I will be puting these 2 on the front.
Re: 14" tire size...(del sol Si wheels) (EKEJ6)
I know the stock tire size was 185 60 H14 for that wheel. If I remember correctly the honda 14 inch wheel is 6" wide where most aftermarket wheels in 14" are 7 " wide. I think you are as wide a the stock wheel can fit. Someone correct me if I am wrong
Modified by instructor74 at 1:47 PM 9/12/2006
For the Si model the stock tire is a P185/60R 14 (22.7 inches around)
For the VTEC model the stock tire is a P195/60R 14 (23.2 inches around)
What engine and speed cluster are you using?
