obd1 engine harnes on obd0 swap...
From: 9/11/01 WTC Never Forget, United States Of America
K so here is the thing I put a coupe DX obd1 engine harness on my DX hatch with a 1st gen obd0 B16A should there be any sensors left over if so which and what color wires would they be
Also do I need to change the fuel injectors from obd0 to 0bd1
There shouldn't really be any plugs left over. There will be a few plugs that are different though.
Distributor plugs, fan switch plug, and injector plugs.
You either need to swap to obd1 injectors(your DX injectors will work) or wire in a resistor box.
If you use obd1 injectors, you wont have to change the injector plugs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slopoke »</TD></TR><TR><TD CLASS="quote">There shouldn't really be any plugs left over. There will be a few plugs that are different though.
Thanx Slopoke
</TD></TR></TABLE>Thanx Slopoke
CRAZY-EG9
Oct 16, 2008 02:24 PM
vtecsk8r
Sep 20, 2004 01:21 PM
