*UPDATED* BRAND NEW OMNI LOWER CONTROL ARMS! NEW DESIGN FOR FRONT AND REAR!!
Peter with IAP here to announce another new item! OMNI has just released their new Rear Lower control arms for EG/DC applications! This is in addition to the front lower control arms released just a few months ago. More info below:
New OMNI EG/DC Rear Lower Control Arms:
Brand new design from Omni-Power!
These aluminum arms weight approx. 2.5 lbs less than stock and have a much nicer appearance! Once installed, these can be seen from the rear of the vehicle. Included are:
Two (2) silver rear lower control arms
Polyurethane bushings installed
Adjustable sway bar mounting holes
Abs Mounting Provisions
Applications:
<ul>[*]92-95 Civic (EG) [*]94-01 Integra (DC)[*]88-91 Civic [*]90-93 Integra[/list]
Order your set by Calling the number below, by sending Paypal payment to paypal@iapdirect.com, or by clicking the following link: Click Here [/B]
Price: $199 with free shipping!
New OMNI EP3 Rear Lower Control Arms:
These arms are manufactured out of 7075-T6 Aluminum for the ultimate in strength and weight reduction. They utilize polyurethane bushings and even have aluminum bushing inserts for additional weight reduction. The arms will also arrive with the "infamous" 12 point socket that is nearly unattainable.
Total Weight for both arms is only 2lbs 6.3oz! Included are:
Aluminum Pins for added weight reduction
Special 12 point Socket for stock arm removal
Applications:
<ul>[*]01-05 HONDA CIVIC ALL[*]02+ CIVIC SI HATCHBACK (EP3)[/list]
New Front Lightweight Lower Control Arms
OMNI has another first!!!! Be the first to own the BRAND NEW FRONT LOWER CONTROL ARMS!! This is a brand new item being offered by OMNI-Power that is currently in stock at our warehouse.
Info from OMNI:
Unique only to the Omni-Power product line, our light weight aluminum front lower control arms (FLCA's) are forged with a special exotic high strength aluminum based alloy. Each control arm is then hard anodized to eliminate corrosion and maintain a show quality look. Omni-Power uses a solid design for added strength and U.S. made replaceable polyurethane bushings. These FLCA's are a direct replacement for the front 2 piece design and require no modifications for an easy installation. Typical weight savings adds up to about 7+ pounds depending on the vehicle model.
Applications:
<ul>[*]92-95 Honda Civic [*]94-01 Acura Integra[/list]
Price: $379.99 with free shipping!
PM me if you have any questions!!
Modified by ImportAutoPerformance.com at 2:00 PM 2/9/2007
Applications:
Applications:
Info from OMNI:
Applications:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paul vang »</TD></TR><TR><TD CLASS="quote">nothing for the 88-91 civic/crx for front LCA's?</TD></TR></TABLE>
Not currently.
Not currently.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol »</TD></TR><TR><TD CLASS="quote">pm'd you</TD></TR></TABLE>
All PM's replied.
All PM's replied.
