Attaching the shiftboot to the knob on an 00-01 ITR
Old Sep 12, 2006 | 06:29 AM
Todd00's Avatar
I said I don't want a title!
Default Attaching the shiftboot to the **** on an 00-01 ITR
Has anyone found a good way to attach the shiftboot up closer to the shiftknob on the 00-01 ITR?
The way it is, it just looks unfinished to me. I know some of the newer hondas use a pretty slick way with a plastic insert (RSX, 01-05 Civic optional ****), but wanted to see if there was a known way.
BTW--I did not search, so STFU
Old Sep 12, 2006 | 06:38 AM
Jon D's Avatar
Default Re: Attaching the shiftboot to the **** on an 00-01 ITR (Todd00)
id like to know if anyone has got the jdm boot to fit tight up agains the bottom of a 97-98 ****, those clips are in the way.
Old Sep 12, 2006 | 08:09 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: Attaching the shiftboot to the **** on an 00-01 ITR (Jon D)
I have a skunk2 **** and have a washer under the boot that keeps it up close to the know. Hard to explain, I'll see if I can get a pic tonight...
Old Sep 12, 2006 | 10:40 AM
erikiksaz1's Avatar
Default Re: Attaching the shiftboot to the **** on an 00-01 ITR (walker111)
A couple of zip ties on the shifter to keep the boot up?
A dab of epoxy on the zip tie should keep it in place.
Old Sep 12, 2006 | 11:05 AM
Todd00's Avatar
Default Re: Attaching the shiftboot to the **** on an 00-01 ITR (erikiksaz1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by erikiksaz1 &raquo;</TD></TR><TR><TD CLASS="quote">A couple of zip ties on the shifter to keep the boot up?
A dab of epoxy on the zip tie should keep it in place. </TD></TR></TABLE>
Yeah, a zip tie below the boot is a decent idea. IIRC, that's how the RSX keeps its boot up with the aluminum shiftknob.
I may give that a try.
Old Sep 12, 2006 | 02:29 PM
Todd00's Avatar
I got to thinking a little more. I bet a band clamp on the shift lever (inside the boot) would hold the boot where I wanted it
Old Sep 12, 2006 | 02:57 PM
LunchboxZT's Avatar
I recently finished fitting my OEM JDM Honda boot (red stitch).
I kinda see where you're comming from with attaching it to the **** but the boot itself doesn't appear to have enough slack for this. If I try holding the boot up closer to the **** with my hand, then moving the shifter to Reverse the boot gets too tight. Anyone else notice this? I've just learned to live with it, eventually it'll wear in and settle, but all in all I think it looks nice.
Old Sep 12, 2006 | 03:13 PM
mugenracer's Avatar
I have more important things in my life to be getting bothered about
Old Sep 12, 2006 | 07:14 PM
Todd00's Avatar
Default Re: Attaching the shiftboot to the **** on an 00-01 ITR (LunchboxZT)
Yeah, I have the JDM ITR boot as well. One could always leave a little slack to allow the shifter to reach all gears without stretching.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I have more important things in my life to be getting bothered about </TD></TR></TABLE>
Glad you had time to tell us that. Onviously your life wasn't important enough to not post in this thread
Old Sep 13, 2006 | 12:26 PM
cool guy name
Like I said above, I have a washer underneath that makes the boot sit where its at. Its kind of a PITA to get the **** on straight but once you do it looks good! Mine has been this way for over a year now.
Mar 30, 2008 05:14 PM
rocket30004
Oct 25, 2006 04:07 AM
fackyou
Sep 26, 2006 07:31 AM
99fbpem1
Aug 25, 2006 10:25 PM
Buckshot
Feb 5, 2003 10:50 PM
