starter went out need help
Old Sep 11, 2006 | 10:00 PM
tchen415's Avatar
Default starter went out need help
So the past few days i noticed it took a few more seconds to start the car. Like it would crank an extra 2 seconds to start. So today after work it just woundnt start. Wouldnt even crank. Just clicking sounds. Finally got it to start by beating the starter and putting it in nuetral (its an auto) and it finally started.
Well im just wondering if it is my starter that is causing this problem. So i can get it replaced. Thanks in advance.
Old Sep 12, 2006 | 06:02 AM
notoriousB's Avatar
Default Re: starter went out need help (t0EkNEE415)
sounds like it could be a starter or starter solenoid to me. is your battery at 100% charge?
Old Sep 12, 2006 | 07:42 AM
specbb6's Avatar
some autopart stores can check alternator, starters and batteries. I'd take it to autozone and have it checked. I dont believe they can check the starter in the car, though, you will have to take it off your car to have it checked.
Old Sep 12, 2006 | 07:43 AM
specbb6's Avatar
btw, if its making that clicking sound is very likely to be the starter.
Old Sep 12, 2006 | 08:49 AM
iam7head's Avatar
Default Re: starter went out need help (specbb6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specbb6 &raquo;</TD></TR><TR><TD CLASS="quote">btw, if its making that clicking sound is very likely to be the starter.</TD></TR></TABLE>
if it would just stick out and wouldn't turn.
actually you can test the start without much tool.
+ and -, and there's a trigger(connecting both end)
it should stick up and spin
Old Sep 12, 2006 | 11:07 AM
tchen415's Avatar
thanks for the info. But this morning when i tried starting it up it didnt, but i hit the pedal and gave it a some gas and it started up fine. I turned it off and on giving it some gas and it started up fine. I dont know why its like that. Any ideas?
Old Sep 12, 2006 | 04:55 PM
hondadude's Avatar
It is probably the starter contacts, they are very cheap and easy to replace; but because you have a TOP SECRET make and model, you can just go pay thru the nose for a new starter.
http://members.troublecodes.ne...t.jpg
Giving it gas or not has nothing to do with the contacts in the starter
azandford
Apr 29, 2010 06:03 AM
Scud
Oct 31, 2007 03:56 PM
skn181
Mar 23, 2007 06:02 PM
00fbp
Jul 15, 2003 07:30 PM
Goy091
Jul 7, 2002 06:09 AM
