Im runnin stock b16, is exhaust 3" piping to much?
I wanted to get HKS, it has 3" pipiping, and i was wonderin if that is to large? i dont' want to lose any gains, and also. which size cat convertr u guys recommend? thanx in advnace.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djeclipzjv »</TD></TR><TR><TD CLASS="quote">what if i plan to install force induction in couple of months? is 3" really a major lost in power?</TD></TR></TABLE>
It will loose power in NA mode, but it will be all good with the turbo. If you're gonna install a turbo later do the 3".
liam
liam
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liam821 »</TD></TR><TR><TD CLASS="quote">It will loose power in NA mode, but it will be all good with the turbo. If you're gonna install a turbo later do the 3".
liam</TD></TR></TABLE>
With the 3" on a stock B16 the exhaust will not provide any backpressure, therefore you will be losing power. But if you plan on going boost soon then have fun with it!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DoraThaMuthaF*ckinExplora »</TD></TR><TR><TD CLASS="quote">With the 3" on a stock B16 the exhaust will not provide any backpressure, therefore you will be losing power. But if you plan on going boost soon then have fun with it!
It will have plenty of backpressure, he's not changing the header.
IMO, don't buy it now. You will go through a lot of money to make it fit on your cat and on your header, then you'll have to spend more to fab it onto a flex pipe and 3" DP when you go turbo.
Save your pennies for the turbo first, then just run open DP till you get an exhaust.
</TD></TR></TABLE>It will have plenty of backpressure, he's not changing the header.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 »</TD></TR><TR><TD CLASS="quote">OPEN DUMP TURBE IS??</TD></TR></TABLE>
Open dump means you dont run an exhaust at all...the exhuast just dumps out of the downpipe ie open dump.
liam
liam
arite, i'll take your guys advice. Well, the only reason i wanted to change my exhaust was becuase i bought the Si with a N1 exhaust, but that dam thing was rusting and had a hole, so i tore out the entire thing and put in complete stock one in. I had it done at sum mexican shop for a hundred bux, they put new piping . muffler, cat. ect. Im gettin really annoyd at it because it has no low end power. Like when i downshift, it feels like the dam thing wants to explode. so im just really irritated. I will definitely wait on the HKS, but for now. what you guys recommend? i was going to get a magna flow muffler only, but thats like a $100, hmmm. any suggestions? and yes i do have a DC header on my engine with CAI. sorry did'nt mention that earlier. Thanx for the post fellas.
dude i would stick with a stock muffler with a 2 1/4 straight pipe. bannncheeeee!
You lost torque buying that huge muffler but you did gain horse power. Since you have a 1.6 you need all the torque you can get. I mean it's only a 1.6...
liam</TD></TR></TABLE> would that be like runnin gopen header, loud as expletive
RsxType-Stitch
16
Sep 7, 2005 07:52 PM
