how to adjust rear drum brake?
Old Sep 11, 2006 | 08:21 PM
95GGSSRR's Avatar
Default how to adjust rear drum brake?
i have 91 CRX DX with rear drum brake. If i raise the rear wheel off the ground and try to spin with hand, the passenger side has drag. The driver side can move freely. How do I adjust my passenger side? is this adjustable? please help me, i am pretty new to CRX.
Thanks in advance.
Old Sep 11, 2006 | 08:40 PM
Tippyman's Avatar
Are you sure it's the drum brakes? Could just be your wheel bearing or someting is dragging or getting sticky.
Old Sep 11, 2006 | 09:54 PM
95GGSSRR's Avatar
Default Re: (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure it's the drum brakes? Could just be your wheel bearing or someting is dragging or getting sticky.</TD></TR></TABLE>
hehe ... i m not sure the drag is from the brake. Can the bad wheel bearing cause dragging?
How do I check where is the drag come from? Please advice.
Old Sep 11, 2006 | 10:34 PM
Tyson's Avatar
Default Re: how to adjust rear drum brake? (95GGSSRR)
put the rear on jackstands. take the wheel off. make sure the parking brake is OFF. you SHOULD be able to just carefully pry the drum straight off. if its giving a fight, then you can help it with some regular 10 or 12mm socket bolts in those holes that have thread, in between the wheel studs.
once theyre off, youll see the star adjuster. notice that it has a one way locking device. you can pry that away to readjust the other way. play with that. it should be self adjusting, however it could use some help.
with the drum off, you can rotate the hub. if you feel any roughness, then it has to be the bearing. thats how you diagnose the bearing.
Old Sep 11, 2006 | 10:39 PM
95GGSSRR's Avatar
Default Re: how to adjust rear drum brake? (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">put the rear on jackstands. take the wheel off. make sure the parking brake is OFF. you SHOULD be able to just carefully pry the drum straight off. if its giving a fight, then you can help it with some regular 10 or 12mm socket bolts in those holes that have thread, in between the wheel studs.
with the drum off, you can rotate the hub. if you feel any roughness, then it has to be the bearing. thats how you diagnose the bearing.</TD></TR></TABLE>
thanks... i'll try that
bigJOE671
Jan 10, 2013 08:45 PM
street_ride14
Sep 3, 2011 08:35 AM
Honda3133
Aug 28, 2011 05:42 PM
fbjunkie53
Sep 10, 2007 02:04 PM
cccya
Oct 25, 2002 06:06 PM
