Suspension & Brakes Theory, alignment, spring rates....
When i turn left my suspension makes a wierd noise?? help please
Old Sep 11, 2006 | 07:47 PM
J.nguyen's Avatar
Default When i turn left my suspension makes a wierd noise?? help please
https://honda-tech.com/zerothread?id=1760701 <---- HELP PLEASE!!!!
Modified by Jesse. at 12:24 PM 9/23/2006
Old Sep 12, 2006 | 10:03 AM
PIC Performance's Avatar
Default Re: When i turn left my suspension makes a wierd noise?? help please (Jesse.)
What type of sound? scraping, knocking, rattling, grating, grinding? Is it during normal turning speed, low speed, high speed?
Old Sep 12, 2006 | 12:43 PM
J.nguyen's Avatar
Default Re: When i turn left my suspension makes a wierd noise?? help please (PIC Performance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PIC Performance &raquo;</TD></TR><TR><TD CLASS="quote">What type of sound? scraping, knocking, rattling, grating, grinding? Is it during normal turning speed, low speed, high speed? </TD></TR></TABLE>
i was gonna try to explain this in my initial post, but i was gonna go get a final judgement after i drove it around a bit more . so its at about 10mph.. so i guess slow / medium speed.. like if i were to put alot of pressure on my suspensin but doing a u turn at a normal speed.. or were to make a left turn while going up a hill..
the sound sounds like a knocking noise.. or sounds like coil over noise.. u know the noise u get when it sounds as if the coil overs are compressing?
Old Sep 12, 2006 | 01:34 PM
I've heard knocking noises coming out of a suspension before, its usually the upper mount being too loose, like if the two 14mm nuts up top are not tightened.
It could also be excessive movement in the control arms or knucke shifting around due to busted bushings and balljoints. What sort of condition are you bushings in, how old are they? If they are all worn out, that could allow lots of unwanted motion in a corner.
Old Sep 12, 2006 | 02:33 PM
J.nguyen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PIC Performance &raquo;</TD></TR><TR><TD CLASS="quote">I've heard knocking noises coming out of a suspension before, its usually the upper mount being too loose, like if the two 14mm nuts up top are not tightened.
It could also be excessive movement in the control arms or knucke shifting around due to busted bushings and balljoints. What sort of condition are you bushings in, how old are they? If they are all worn out, that could allow lots of unwanted motion in a corner. </TD></TR></TABLE>
ic. ill try tightening the 14mm nuts. but can my suspension be installed backwards? i think its coming from the RIght side suspension when i turn left. my bushings are OEM stock so maybe they are worn out.. i only replaced my axles and suspension thast it.
Old Sep 12, 2006 | 04:22 PM
Unless they come with brake line brackets, most aftermarket coilovers can fit either side of the car (left or right), so that should not be an issue.
You're correct, when you turn the car left you will load the right side of the car, particularly the front, and so that might be causing whatever is wrong at that corner to start making noises.
If you have time, I would recommend getting the car up in the air with the wheel off and see if anything is out of the ordinary, and make sure you followed the installation instructions correctly. Despite what some people think, coilovers are not a drop-in and go type of mod, and with all the nuts and bolts involved, its easy for a first timer or inexperienced user to miss something during the install, or install something incorrectly.
Is the sound just one knock? Like "thud" and thats it? If so, you might be too low and something is bottoming out.
Old Sep 12, 2006 | 04:50 PM
J.nguyen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PIC Performance &raquo;</TD></TR><TR><TD CLASS="quote">Unless they come with brake line brackets, most aftermarket coilovers can fit either side of the car (left or right), so that should not be an issue.
Is the sound just one knock? Like "thud" and thats it? If so, you might be too low and something is bottoming out. </TD></TR></TABLE>
na it sounds like a clunk clunk clunk. na im not new to intsall coil overs, just sayin that when me and my friend was doing my motor swap recently, i took out the whole suspension just to take a look at it and i bolted it back up but was just wondering if i had bolted it up wrong ie backwards.. well first off imma see if the bolts are tightened.. then if it was then imma take it up and remove the suspension and put it in the other way and hopefully that will stop the noise.
Old Sep 12, 2006 | 04:58 PM
Oh thats right, you had posted in another thread about this right?
If you took those front forks off, then its possible you put those in backwards, because one side is arched out further to accomodate the axle. Check that, maybe its rubbing.
Old Sep 12, 2006 | 05:19 PM
J.nguyen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PIC Performance &raquo;</TD></TR><TR><TD CLASS="quote">Oh thats right, you had posted in another thread about this right?
If you took those front forks off, then its possible you put those in backwards, because one side is arched out further to accomodate the axle. Check that, maybe its rubbing.</TD></TR></TABLE>
yeah. so lets say it is put in backwards. have i hurt anything really ? just my tire a little right? i didnt damage any shocks or nothing. but yeah i just remove my tire and check to see if my suspension is rubbing? theres no arrow or anything to show which way its suppose to go in correctly?
Old Sep 12, 2006 | 06:00 PM
look in this picture:
The left side of the picture if the front of the car, right side if the picture is the front. The front side arches out slightly further to accomodate the axle.
Old Sep 12, 2006 | 07:48 PM
J.nguyen's Avatar
The left side of the picture if the front of the car, right side if the picture is the front. The front side arches out slightly further to accomodate the axle.</TD></TR></TABLE>
huh can u reword that again please..? the left side of the picture if the front of the car? please re-word its twisting my brain.
Old Sep 12, 2006 | 10:12 PM
mRek9R's Avatar
That picture above is depicting the how the driver side should look like when shock + fork is fully assembled. Notice the 14mm bolt also, on both sides the head of that bolt should always be facing toward the rear of the car.
Also, i'm wondering where you got that spacer! I've never noticed it in my kits that I buy, was that custom or is that something that Koni offers? -koshi 8)
Old Sep 15, 2006 | 09:26 PM
J.nguyen's Avatar
Default Re: When i turn left my suspension makes a wierd noise?? help please (mRek9R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mRek9R &raquo;</TD></TR><TR><TD CLASS="quote">That picture above is depicting the how the driver side should look like when shock + fork is fully assembled. Notice the 14mm bolt also, on both sides the head of that bolt should always be facing toward the rear of the car.
Also, i'm wondering where you got that spacer! I've never noticed it in my kits that I buy, was that custom or is that something that Koni offers? -koshi 8)</TD></TR></TABLE>
ic.. well im gonna take off my wheel and check and post pics tomorow..
Old Sep 15, 2006 | 09:51 PM
chrisw85's Avatar
that spacer is the oem brake line bracket on the cars thats on the shocks. Not really needed in my opinion, thats what a couple zip ties are for. Plus you can mount the shock lower into the fork to gain some piston travel.
Old Sep 16, 2006 | 01:52 PM
J.nguyen's Avatar
Default Re: When i turn left my suspension makes a wierd noise?? help please (chrisw85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PIC Performance &raquo;</TD></TR><TR><TD CLASS="quote">look in this picture:
hmm juss opened my wheel and looked. my passenger side arches in front too. and the bolt is facing the rear... hmmm now what can be the problem!!!
Old Sep 16, 2006 | 03:35 PM
J.nguyen's Avatar
here is a pic of it (passenger side looking to the rear of the car)
pic of it taken looking straight from the hub
Old Sep 17, 2006 | 12:39 PM
J.nguyen's Avatar
NOBODY can HELP ME??!!! is it my TIE RODS or RACK AND PINION?!?!?!? HELP ITS PSISSISINGN ME OFFFFFFF
Old Sep 17, 2006 | 10:50 PM
91tealhatch's Avatar
im having the same problem in my 91 hatch!!!!!!!!!!!!! help us!!!!!!!!!!!!! but mine is only when i accelerate when turning left, it doesnt do it when im not doing it
Old Sep 17, 2006 | 10:51 PM
J.nguyen's Avatar
Default Re: When i turn left my suspension makes a wierd noise?? help please (91tealhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91tealhatch &raquo;</TD></TR><TR><TD CLASS="quote">im having the same problem in my 91 hatch!!!!!!!!!!!!! help us!!!!!!!!!!!!! but mine is only when i accelerate when turning left, it doesnt do it when im not doing it</TD></TR></TABLE>
yeah it only makes it when i accelerate . i think when im in neutral and turn left it dsnt do it.. i belive..
Old Sep 17, 2006 | 11:24 PM
me too. im lost, its been like this in my car for about 4 months
Old Sep 18, 2006 | 07:08 AM
J.nguyen's Avatar
dang.. then someone needs to help us!!
Old Sep 18, 2006 | 09:12 PM
J.nguyen's Avatar
ANYONE??!?!?!!
Old Sep 18, 2006 | 09:16 PM
pretty pretty please!!!!!!!!!!!!!
Old Sep 19, 2006 | 12:27 PM
J.nguyen's Avatar
it CAN be that my Intercooler is hitting against my car because it isnt welded on, just zip tied.. but iono if it can be the case.. if so i would hear it while i was going straight and 1st gear while it vibrates but nope, only when i turn left and when i accelerate.. PLEASE HELP
Old Sep 19, 2006 | 01:37 PM
Aah, remanned axles. Not sure how good NAPA is, but Vatozone reman axles can be hit or miss. Double check yours, and make sure you didn't pop out that tripod joint (or whatever its called) during installation, and make sure it was pushed all the way into the tranny and the hub.,
