Where to refill oxygen/acetylene (sp?) tanks in MD
Old Sep 11, 2006 | 07:05 PM
The Phil's Avatar
Default Where to refill oxygen/acetylene (sp?) tanks in MD
I'm picking up a used oxyacetylene welder tomorrow, and I'm wondering where I should go to get the tanks refilled when I need to, in Maryland. Focusing on the cheap here, since I'll be just practicing for a while to get a feel for it.
Thanks.
Old Sep 11, 2006 | 07:22 PM
ManBearPig4silly's Avatar
You will have to provide proof of ownership and/or get the tanks recertified depending on how old they are. Just look up "welding supply" in the phone book. You should have an Airgas around somewhere.
Old Sep 11, 2006 | 07:25 PM
The Phil's Avatar
Default Re: (I4sillypwr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I4sillypwr &raquo;</TD></TR><TR><TD CLASS="quote">You will have to provide proof of ownership and/or get the tanks recertified depending on how old they are. Just look up "welding supply" in the phone book. You should have an Airgas around somewhere. </TD></TR></TABLE>
Proof of ownership? Of the tanks I'm guessing?
What would be an example of proof of ownership? I'm picking up the welder tomorrow, so I want to make sure I get everything I need.
How much would all of that cost?
Old Sep 12, 2006 | 09:14 AM
dash's Avatar
Default Re: (The Phil)
this place is pretty good,
Baltimore Welding Supply Co
(410) 282-2800
2718 N Point Blvd, Dundalk, MD 21222
Old Sep 12, 2006 | 12:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Phil &raquo;</TD></TR><TR><TD CLASS="quote">
How much would all of that cost?</TD></TR></TABLE>
I bought an oxy setup at a garage sale and I just had the guy write up a bill of sale. Most gas places will stamp their tanks(the ones they lease) and no other place can fill them so they just need to know that you own it and not some other gas place. On that note look for any gas company names stamped into the top of the tanks. Don't want to get stuck with something you can't fill I think I had to pay like $20 to have both my act and oxy tanks inspected marked with my name and then I was good to go.
Old Sep 12, 2006 | 04:30 PM
Laserjock's Avatar
i bought (not rented) an oxy and acetylene tanks a year ago from airgas in NOVA/alexandria. i'll have to get home and check receipts for costs.
www.tinmantech.com &lt;- lotsa tips and materials here. i bought some SS flux and aluminum flux. My SS welds look good but alum sux @$$ at the moment.
www.weldingweb.com &lt;- has some topics on gas welding
www.cut-like-plasma.com &lt;- another site to visit
i think I4sillypwr is referring to tank certification. tanks have to be re-tested every few years.
Old Sep 12, 2006 | 05:53 PM
2kjettaguy's Avatar
Default Re: (Laserjock)
Where I go: http://www.robertsoxygen.com/
dfoxengr's Avatar
if theyre the big ones, theyre leased and you cant get them refilled, so theyre as good as trash.
biggest size you can own is 80 ft^3
Old Sep 12, 2006 | 06:10 PM
Laserjock's Avatar
Default Re: (dfoxengr)
Here's what I paid for a filled set:
$140 for 75 Cu ft of ACETELYNE
$187 for 80 Cu ft of OXYGEN
did not know this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr &raquo;</TD></TR><TR><TD CLASS="quote">if theyre the big ones, theyre leased and you cant get them refilled, so theyre as good as trash.
biggest size you can own is 80 ft^3</TD></TR></TABLE>
Old Sep 12, 2006 | 06:40 PM
dfoxengr's Avatar
that is only true since he is not the one that leased them though.
you can go lease them yorself for like 50$/year and get them refilled for like 30-40$ each as many times as you like though.
good luck.
Old Sep 13, 2006 | 01:47 AM
The Phil's Avatar
They're tiny tiny little tanks. They look like they're 5 cubic feet at most
Old Sep 13, 2006 | 03:21 AM
dfoxengr's Avatar
5 cuft would be like 6 inches tall and serve no purpose whatsoever.
the volume is when the gas is compressed.
80 cuft tanks arou about 8" diameter, and roughly 3ft tall.
if youve got something similar then you can get it refilled anywhere.
i like
Old Sep 13, 2006 | 10:49 AM
The Phil's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr &raquo;</TD></TR><TR><TD CLASS="quote">5 cuft would be like 6 inches tall and serve no purpose whatsoever.
i like
http://www.robertsoxygen.com</TD></TR></TABLE>
I thoght something was off. They're small tanks though. About 6" diameter, 1-1.5ft tall.
Old Sep 13, 2006 | 11:57 AM
dfoxengr's Avatar
those are the 10/20 cu ft ones. green is O2, and normally its alittle bigger, it would be 20 in that case, red is aceto, and it should be 10. sometimes both are 10 though.
Old Sep 13, 2006 | 06:38 PM
Laserjock's Avatar
Ok, here's your first welding project!
Old Sep 14, 2006 | 04:25 AM
LOL. No he should try to oxy/act weld two razor blades together and use paperclips as filler.
The business end of the razor blades Phil not the ***** end.
9.3.S.I.L.U.D.E.
Honda Ruckus and Scooters
Aug 31, 2008 09:48 PM
The GreenD16
Honda Motorcycles
14
Aug 1, 2008 05:47 PM
Honda_ThuGZ
Feb 15, 2007 11:17 AM
AssPenny
Jan 31, 2006 05:11 PM
