b16b and b18C5 weight difference?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice »</TD></TR><TR><TD CLASS="quote">Does it really matter, I mean honestly?</TD></TR></TABLE>
On the limit maybe (polar moment of inertia and roll center)...
Yes,the differnece in weight is 14-15 lbs. Almost everything is lighter on the ctr motor, things you wouldn't even think would be lighter, that add up to the 14 lbs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boylovecar »</TD></TR><TR><TD CLASS="quote">Yes,the differnece in weight is 14-15 lbs. Almost everything is lighter on the ctr motor, things you wouldn't even think would be lighter, that add up to the 14 lbs.</TD></TR></TABLE>
How so? The only differences between the B16B and B18C5 are the crank, rods, and pistons. I know CTR pistons are heavier than ITR pistons (larger dome). My assumption would be the ITR motor has less mass, by a few grams.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20powereDA »</TD></TR><TR><TD CLASS="quote">all b-series motors are within 5 lbs. of each other. with the exception of the old b20a that came in the old preludes</TD></TR></TABLE>
i read this a few months back, i wish i had the link but oh well
Alright if it means that much, the crank pulley 3-5 lbs less, the starter 3-5 lbs less, and the flywheel, 3lbs less. the crankshaft, rods and pistons about 1lb less. The heads are identical except the ctr has a slightly more aggresive intake cam. the blocks castings are identical, but internals are different.
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
0wn3d!!! nice explanation
except i disagree on the flywheel portion they bothe come with lightened flywheels
Your right in that they are both lightened, but I believe the ITR is 18.5lb where as the CTR is 16lb. I could be wrong though as I've not actually put both on a scale.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darkane »</TD></TR><TR><TD CLASS="quote">Its the same block!
wrong. deck height is taller on b18b than b16. cant remember the exact difference though
</TD></TR></TABLE>wrong. deck height is taller on b18b than b16. cant remember the exact difference though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ED9man »</TD></TR><TR><TD CLASS="quote">Just out of curiousity, how much heavier is the taller B18 block than the B16 block?</TD></TR></TABLE>
The B16B is the same block as a B18C5. The internals are different.
The difference in deck height between a B16A and a B18B is ~25mm
atermizi
Feb 18, 2004 12:37 PM
