subs dont work, amp gets hot
hey i dont know whats wrong with my system, my amp gets really hot when the car is on and the ground wire gets hot too, when i was driving one day the subs just turned off and i pulled over and the amp was really hot.
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
what load are you running the amp at? Please go more in to depth about your system. What does it consitest of ?
Sounds like a blown amp without a fuse on the power wire, or a blown amp on too thin wiring.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti eater »</TD></TR><TR><TD CLASS="quote">What does it consitest of ?</TD></TR></TABLE>
x2 What size wiring? What size fuse?
Maybe if you post what you are running we could see what caused it. or avoid anthor problem. Just a ideal.
Whats causing it, is a blown power supply in the amplifier. The transistors are probably partially shorted which is why the fuse doesn't blow.
This is probably one of the most common failures in an amplifier. Usually caused by over heating or just age.
If you want to sell the amp send me an IM.
Think of a transistor as kind of a relay/resistor. You apply a voltage to the "gate" of the transistor. This allows current to flow from the drain-source. Now vary the gate voltage and you vary the amount of current flowing from drain to source. This is where the resistor analogy comes into play. You are changing the impedence between the drain and source.
Over simplified obviously but should help most of you understand.
Day_Walker
Audio / Security / Video
Apr 24, 2009 06:45 AM
SIReg9
15
Mar 8, 2004 06:18 PM
