Replacement rockers CRX
Old Sep 11, 2006 | 04:45 PM
gdh8su's Avatar
Default Replacement rockers CRX
I am working on a 90 hf and the rockers need replaced. The only place to get a new one is Honda. Not a big deal! The question is when welding the new one in can I butt weld it? A local body shop said that I would have to cut a piece of the old rocker and weld it in behind the new one. Because of it being a unibody car! If somebody knows it would really help.
Thanks for any info
Old Sep 11, 2006 | 04:50 PM
cbp_crx's Avatar
Default Re: Replacement rockers CRX (gdh8su)
its not a good idea to butt weld it, if you want to use a used peice, use an over sized piece and trim out the rust on it on the old one, knock the origional one down a bit and weld the new one over the top of it, using a weld through primer
Old Sep 11, 2006 | 05:22 PM
gdh8su's Avatar
Default Re: Replacement rockers CRX (cbp_crx)
So I do want to reinforce it when welding the new one in. I just wanted to make sure that was the way to do it. He said that he cuts out the old one and then takes a good strip from the old one drills holes in both panels tacks them then welds in place. What could I use for keeping the rust away between the two panels? I have to get new ones every CRX I find has rusted rockers! Also Would I have do the same for patch panels for the quarters?
Old Sep 12, 2006 | 01:07 AM
crxdriver1991's Avatar
use zinc rich primer in between the two where you will not be welding and weld through primer where you will be welding
kaymoto
19
Jul 18, 2013 07:58 AM
msinsky14
Paint and Body
25
Oct 9, 2007 04:44 PM
baconcrx
Welding / Fabrication
May 5, 2006 05:43 AM
padge
Apr 14, 2003 10:31 PM
hondasir1988
Sep 24, 2001 07:29 PM
