Are these bad synchro symptons or shift linkage issues?
Hey guys, on Labor Day I installed an SI transmission with some buddies of mine. Everything was golden until we got to the bitch pin; the furthest we could get it in was about 5mm sticking out. That's it. Anyway since we were on a time constraint we left it as is. No problems on the drive home or what not but I noticed when I go to downshift in this order, it grinds:
3rd gear --> put clutch in --> down to neutral, down to 2nd gear **crunch**
Mind you it only happens on a downshift and I press the clutch to go in. I usually rev match before I let the clutch off of the lower gear.
Fast forward to today, I install some shifter bushings and try to get the bitch pin in all the way. No go so since it was getting dark I railed a ******* 10mm in there on the other side incase that was causing a problem
Install everything and still I get the same ******* crunch. Drive it around and the same thing. However if I downshift in the above order below 10-15mph there's no grind. Also it doesn't grind when I shift from 1st --> 2nd. There is almost a soft clap sound in the shifter area. It's not grinding but it feels like it may be trying a bit harder. The other gears are all fine.
It **DOESN'T** grind when I go from 3rd --> neutral --> let off clutch --> rev match it -->press clutch --> 2nd gear. If anything I still get that muted clap sound.
Do you think this is an issue with the bitch pin, clutch cable, shifter assembly or am I just trying to convince myself that the tranny I bought (which I was told had 100% no grinds) isn't faulty. Thans HT
man o man
thats the thing i hate about transmissions
Unless you drive the car you purchasing it from you never know what the matter with it. And tranny don't have a tim elike like engines and go at any time
my advice spend the money to get the tranny rebuilt with everything so yo uknow for sure what yo u have.
sounds like a stretched/chewed up blocker ring. easiest way to fix it is to get a new synchro hub.
a worn fork can give you some issues similar to this. won't know til you open the case.
sucks.
sucks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kylefakesi-r »</TD></TR><TR><TD CLASS="quote">ever been stabbed in the stomach and tried to put a bandaid on it?
synchromesh is kinda like that.</TD></TR></TABLE>
You guys think this would have anything to do with the fact that I don't have a front transmission mount?
I always put Penzoil Synchromesh in my trannies. In all three that I've run, never had a grind. That's prolly just cause they were good trannies, but synchromesh keeps it that way.
Here: http://sms-products.com/TrannyKits.html
they are located right near me. Good peeps. E-mail them if u want one. They aren't usually in stock but they can have them in in a couple days.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX_1.8T »</TD></TR><TR><TD CLASS="quote">This thread reminds me of my transmission.
I guess we have the same issues.</TD></TR></TABLE>
me too, double clutching is the way to go
I guess we have the same issues.</TD></TR></TABLE>me too, double clutching is the way to go
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hond@ »</TD></TR><TR><TD CLASS="quote">me too, double clutching is the way to go
Why down shift. ride in nutral till stop.
But for fixing it. please let me know. My 5th gear decided to go, and I don't know if it syncros or shift linkage but cant afford to eliminate one and have it be the other.
my Y1 tranny grinds into 5th after 3000 rpm but im guessing its the syncros....but then again the more I tighten my clutch the less it seems to get. so try adjusting your clutch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LigerZeroWPC »</TD></TR><TR><TD CLASS="quote">my Y1 tranny grinds into 5th after 3000 rpm but im guessing its the syncros....but then again the more I tighten my clutch the less it seems to get. so try adjusting your clutch.</TD></TR></TABLE>
This is what I was thinking too. I'm sure the car wouldn't mind a new clutch cable after having the same one for 13X,XXX miles on it. And by tighten do you mean making the clutch pedal catch real low or real high since tightening the clutch pedal (righty tighty) makes it grab higher and vice versa.
Also would this be happening because my front transmission mount isn't on?
mojord
13
May 21, 2002 08:08 AM
