clutch problem! somebody help
ok so i put my new clutch and my ys1 tranny in today. had a helms manual and went step by step. got it all in and torqued to spec, i went and turned the crank w/ a ratchet and the trannys not spinning, i made sure it was in gear, i even took it out and put it in neutral and reverse, still nothing. clutch cable is hooked up too. is it even supposed to spin? it did the 1st turn i did then nothing. ahh i dont know im confused.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GroundZer0 336 »</TD></TR><TR><TD CLASS="quote">ok so i put my new clutch and my ys1 tranny in today. had a helms manual and went step by step. got it all in and torqued to spec, i went and turned the crank w/ a ratchet and the trannys not spinning, i made sure it was in gear, i even took it out and put it in neutral and reverse, still nothing. clutch cable is hooked up too. is it even supposed to spin? it did the 1st turn i did then nothing. ahh i dont know im confused.</TD></TR></TABLE>
I've never turned the crank after a tranny install or clutch job. I just install the tranny, and when the clutch cable is adjusted, drive it.
danno33
12
Sep 30, 2012 08:46 PM
