Possible to run engine with valve cover off? & Idle speeds - OIL FIESTA!
Old Sep 11, 2006 | 01:45 PM
drumminforev's Avatar
Default Possible to run engine with valve cover off? & Idle speeds - OIL FIESTA!
So i need to determine exactly which of my valves are ticking like no tomrrow. I did my adjustment and they still tick so loud. I wonder if its possible to idle the car with the valve cover off, or how much oil spewage would i expect.
And is there any way i can drop my idle to about 500-600. Cuz no matter WHAT my car idles at 1000 at operating temp. My butterfly is fully closed also. No obvious vacuum leaks.
Old Sep 11, 2006 | 01:48 PM
eeleaj's Avatar
Default Re: Possible to run engine with valve cover off? & Idle speeds - OIL FIESTA! (drumminforev)
i wouldnt suggest running the car without the valvecover. you will spill alot of oil and you will get oil where your spark plugs go
Old Sep 11, 2006 | 01:51 PM
Default Re: Possible to run engine with valve cover off? & Idle speeds - OIL FIESTA! (eeleaj)
I know, my question was HOW MUCH oil would be shooting out past. I have turned on other cars and the oil just makes a look over the cam lobe at an idle, not making a mess.
Old Sep 11, 2006 | 01:53 PM
Lewy. Dee Ayy's Avatar
idk..but if u do it..make a video..it would be awesome to watch.
Old Sep 11, 2006 | 02:05 PM
Luserkid's Avatar
Default Re: Possible to run engine with valve cover off? & Idle speeds - OIL FIESTA! (WhiteOut)
Itll be messy but not that messy. What i normally do is get a stick and put my ear next to it and hear where the ticking is coming from.
Old Sep 11, 2006 | 02:08 PM
M2nR's Avatar
I've started my car before without the valve cover, it was a single cam y8. oil rises so fast and when it gets to the top it just starts splashing everywhere! luckily i turned it off immediately and nuthen happened and just a couple drops of oil but yea i wouldnt try it again or recommend it =/
Old Sep 11, 2006 | 02:16 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteOut &raquo;</TD></TR><TR><TD CLASS="quote">idk..but if u do it..make a video..it would be awesome to watch.</TD></TR></TABLE>
x10 on a vid
dont_tri
Jul 11, 2008 08:43 AM
cm8719500
Mar 30, 2008 12:09 AM
whiteEGlsvtec
Jul 14, 2007 01:55 PM
xSCTYGx
Dec 11, 2003 08:36 AM
Mag00n
15
Oct 20, 2003 05:46 PM
