Suspension & Brakes Theory, alignment, spring rates....
Should i reuse these End Links? if not, where to get new?
Old Sep 11, 2006 | 12:27 PM
KiddEng's Avatar
Default Should i reuse these End Links? if not, where to get new?
I just recieved in a gsr 24mm sway bar and arms... can/should i reuse these endlinks? and just get new bushings for where it mounts to the arm? One of them has a tear in the boot
i was pricing online and for new the cheapest is around 48 bucks each! Where can i find the L-shaped end links for cheaper?
top one has the tear:
thanks
Old Sep 11, 2006 | 02:49 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Should i reuse these End Links? if not, where to get new? (KiddEng)
Definatly purchase new ones. You can get aftermarket endlinks as well. (Function7 makes a nice set)
Old Sep 11, 2006 | 03:58 PM
KiddEng's Avatar
Default Re: Should i reuse these End Links? if not, where to get new? (JDM_Ej)
just priced out from hondaautomotiveparts, 109$ shipped and thats without the 4 rubber bushings, thats another 20$
there are aftermarket links? ...off to search for them
thanks
EDIT: are these the ones your talking about?
i don't know if they offer the L-shaped links though.
Old Sep 11, 2006 | 06:36 PM
vietjdmboi's Avatar
the ones you need are for the front i assume? well those aftermarket ones wont work as they are made for the rear.
Old Sep 11, 2006 | 06:44 PM
KiddEng's Avatar
Default Re: (vietjdmboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietjdmboi &raquo;</TD></TR><TR><TD CLASS="quote">the ones you need are for the front i assume? well those aftermarket ones wont work as they are made for the rear.</TD></TR></TABLE>
yup front sway end links...
those are the only ones i found on function7's website.
im gonna head to napa or pep boys to see what kind of oem replacements they got, i dont' feel like spending $100+ on endlinks.
Old Sep 11, 2006 | 10:28 PM
Tyson's Avatar
unless you find excessive play in those balljoints, i dont see why you shouldnt reuse those linkages.
Old Sep 12, 2006 | 04:16 AM
KiddEng's Avatar
Default Re: Should i reuse these End Links? if not, where to get new? (Tyson)
eh, i'd just rather get new ones since i have them out... also i don't know how long it had a tear in the boot. if i reuse them i'd prolly have to change them out in the future. plus those bushings are beat...rock hard.
thanks
Old Sep 12, 2006 | 08:41 AM
Tyson's Avatar
suit yourself.
i dont see a problem with the donut bushings being hard. the harder the more responsive the swaybar will be.
Old Sep 12, 2006 | 09:06 AM
KiddEng's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">
i dont see a problem with the donut bushings being hard. the harder the more responsive the swaybar will be.</TD></TR></TABLE>
i see what your saying about the rock bushings and being responsive... but isnt' there a point to have some flex or rebound back in the bushing?
why do people upgrade to urethane then if the beat/rock hard rubber will be more responsive?
Old Sep 12, 2006 | 09:09 AM
Tyson's Avatar
beats the hell out of me.
im not a fan of poly anything.
why do you think honda upgrades the linkage to balljoints. there should be no slop with a balljoint. direct connection.
so whatever. do whatever you want.
Old Sep 12, 2006 | 09:22 AM
Andrie Hartanto's Avatar
Like Tyson said, ball joint should be no slop and as good as spherical bearing. All monoball suspension should have no play.
I would reuse the link and just change the boot and repack it with grease.
I also agree with Tyson that Poly has no place in a race car.
sl0waccord
Feb 13, 2012 03:43 PM
MIEj1
Suspension & Brakes
Feb 9, 2012 01:40 PM
amej8
Jul 14, 2011 04:39 PM
PatrickGSR94
Suspension & Brakes
10
Apr 6, 2010 09:02 AM
vbphreak
Mar 14, 2004 07:51 PM
