oil sending unit
Old Sep 11, 2006 | 10:26 AM
airsoft's Avatar
Default oil sending unit
my car is leaking oil and the guy who did my vavles said i needed a new oil sending unit, where are they located on the car and where can i buy one? i searched online but couldnt find one. thanks
Old Sep 11, 2006 | 10:50 AM
Hawkze_2.3's Avatar
Default Re: oil sending unit (airsoft)
What is an oil sending unit? You mean the oil pressure sender, or the oil pump, or oil cooler or what?
Old Sep 11, 2006 | 10:56 AM
airsoft's Avatar
Default Re: oil sending unit (Hawkze_2.3)
oh it prolly was the oil pressure sender, now where would that be located, thanks hawkze
Old Sep 11, 2006 | 11:07 AM
Lewdin' Incognito's Avatar
It is directly under the oil filter. You can get under there and pull the little rubber boot off and see if you are leaking oil. Should be about $30 from Honda. Don't pay for the labor, teflon tape and about 7 minutes is all you need.
Old Sep 11, 2006 | 11:11 AM
Hawkze_2.3's Avatar
Default Re: oil sending unit (Lewdin' Incognito)
Yep, just get under there and check it out. Get it from Honda and replace it yourself if you need to like Lewdin' Incognito said.
turbo-crx
Mar 3, 2009 10:13 AM
ham
Jul 26, 2004 06:26 PM
CHRIS 1.8
Aug 28, 2003 06:01 AM
