Do i need H23 transmission???? HELP
ok i got a 93 prelude si, i installed a stage 3 clutch with new flywheel about 5 months ago and everything was fine except every time i shift into 3rd it shanked a little now i cant even shift into 3rd, everytime i do it throws it back and fourth gear is starting to do the same.... what's the problem??? i think its mine tranny and if it is do yall think i should jus get the h22 JDM?????
when you put the tranny back in how much oil did you put in the trans, i had this problem once after i swapped mine took alittle bit. but it happened cuz i didnt put enough oil in.
