adjusting idle
Old Sep 11, 2006 | 09:19 AM
airsoft's Avatar
Default adjusting idle
i was told i needed to adjust my idle becaue my car dies when im not stepping on the gas. so my question is how do yo do it? thanks
Old Sep 11, 2006 | 09:48 AM
nonvteclude's Avatar
Default Re: adjusting idle (airsoft)
there is a flat head screw on your throttle body just next to the intake pipe. first remove the harness from the iacv (which is located in the front of your intake manifold, it has a gray harness) then with the car on turn that screw until the car idles to the cars spec which i believe is 750 or 800 then plug the iacv back in and idle should be up to normal
Old Sep 11, 2006 | 10:55 AM
airsoft's Avatar
well i guess it wasnt my idle that was messing up my car, it still dies when im not giving it gas, any ideas?
I my honda
Old Sep 11, 2006 | 10:56 AM
soundbomber's Avatar
check the backup fuse
Old Sep 11, 2006 | 11:09 AM
airsoft's Avatar
Default Re: adjusting idle (soundbomber)
the fuse is fine, still trying to figure this out
Old Sep 11, 2006 | 11:20 AM
mgags7's Avatar
do you get a Check Engine Light (CEL)??
if so get us the code....if not, pull your IACV off and clean it out good....its the thing mounted to the front of the manifold....
Old Sep 11, 2006 | 11:21 AM
airsoft's Avatar
Default Re: (mgags7)
no check engine light, i'll try cleaning the IACV
Old Sep 11, 2006 | 07:33 PM
mgags7's Avatar
and clean out your throttle body well
Old Sep 12, 2006 | 07:27 AM
fast_honda's Avatar
That happened to me when I first got my H22A because it had the wrong ECU. So I went from an Accord SiR P0F to a P13 and it runs perfect. Does it seem your car is running on 3 cylinders? It could be a clogged injector, a bad distributor/cap, then there's the wires and plugs you can check. Keep us udated, I'm curious what's wrong with it.
Old Sep 12, 2006 | 07:41 PM
airsoft's Avatar
Default Re: (fast_honda)
i tried fixing the problem myself but i couldnt so i took it to a shop, the guy told me i had a bad oil leak and there was oil on my timming belt, he also said the timming was off, and that the altenator belt was glazed. the car ran perfect till the timing belt broke, after that the vavles were bent and a few little things finally gave.
jah.tien
Jul 14, 2010 10:37 AM
924doorEG
Nov 19, 2007 08:15 AM
EMphaticONE
Jun 25, 2005 06:26 PM
civic-lsi-vtec
16
Dec 24, 2004 05:26 AM
SpeedMonkeyRacing
Jul 19, 2002 09:50 AM
