Anyone know where i can find some seat rail bolts for 99 si?
I need some front seat rail bolts for a 99 si. I need the inner rail, the bolt in the rear or the seat rail for both sides. My car came with some 95 integra seat so the inner rear one was missing. does anyone a place online that i can get it at. Nearest junkyard to me is bout 2 hr away.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument »</TD></TR><TR><TD CLASS="quote">take the bolt from the other side to home depot/lowes, buy a new one?</TD></TR></TABLE>
With something like seat rails, which can be subjected to quite a bit of force in the event of a collision, you really want to make sure that you're using bolts of the proper grade. I'm not certain what grades home improvement stores carry, or what grade the OEM bolts are, but it's certainly worth a bit of caution. They can't be terribly expensive from the dealer, and you'll know you have the correct bolts for the application.
Nah when i say i live 2hr from a junkyard that means i Live on a Farm. Rather then paying $$ for gas on my tundra.
I found http://www.slhondaparts.com, I looked at the diagram on there and If i'm correct i would have to buy # 15,#7,#8 for the driver side and #13,#11,#12 for the passenger side? i got the diagram from http://www.slhondaparts.com. Let me know if this is correct. thanks for the help.
dunno if they are compatible (I bet they are) but I have all the bolts from a 95 civic's seats if those would help you.
If I posted a picture, would you be able to pick out the ones you need?
01celica_gts
Jan 17, 2017 12:31 AM
