Suspension & Brakes Theory, alignment, spring rates....
How to adjust kyb agx?
Old Sep 11, 2006 | 02:32 AM
skytech76's Avatar
Default How to adjust kyb agx?
Hi guy, can someone help me, I installed kyb agx with my old h&r race spring. I keep it at stock and the ride is pretty bumpy like it go up and down. Would it be ok to put my stock oem spring on agx?. Can you guys recommend what setting should I adjusted so the ride will be smoot when go over something. and when adjusting, do I need to jack up the car or not? Thank you.
Modified by skytech76 at 5:12 AM 9/11/2006
Old Sep 11, 2006 | 05:32 AM
RacerXI's Avatar
Default Re: How to adjust kyb agx? (skytech76)
You can put your stock springs on the agx's. You do not need to jack the car up to adjust them either. Try (1) front and rear.
Old Sep 11, 2006 | 09:46 AM
gogogomoveit's Avatar
Use a small flathead on top of the shock shaft. Press down on the screw and turn 1/4 turn for each adjustment. 1 is pretty good for everyday driving.
Old Sep 11, 2006 | 11:53 AM
skytech76's Avatar
Default Re: How to adjust kyb agx? (gogogomoveit)
Thank, I got it nom. Do you guys think that the h&r race spring is too low, will it damage anything suppension system? Willl my stock spring lower my car little bit? I will do aigliment once I settle down with the adjustion.
Old Sep 11, 2006 | 12:25 PM
race spring sucks for street surfaces anyways. Get rid of them and get H&R OE sport springs. It will give you about 1 inch drop all around. Stock springs are too high for my favor.
Old Sep 15, 2006 | 01:31 AM
babyS2K's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gogogomoveit &raquo;</TD></TR><TR><TD CLASS="quote">Use a small flathead on top of the shock shaft. Press down on the screw and turn 1/4 turn for each adjustment. 1 is pretty good for everyday driving.</TD></TR></TABLE>
it's VERY important that you press down first and then turn
Racebrewer
Feb 3, 2008 08:57 AM
slow_ls
Suspension & Brakes
Aug 22, 2006 08:45 PM
tonysaur
Nov 14, 2005 01:34 AM
anekin007
May 28, 2004 03:18 PM
type Gendy
Jul 1, 2003 08:23 PM
