tail lights
ok today on my way home my tail light worked but recently shut off. I went through 9 fuses but they just kept blowing I NEED HELP what should I do to fix this problem?
Make sure your using a big enough fuse.
If thats not it, check your grounds. To do this, just look at your wiring, and find the black wire(s). you may have a loose ground
Other then that IDK
Other then that IDK
si-ej1
Nov 10, 2011 07:38 AM
d16y8crx
Jun 14, 2009 06:58 PM
