synchros Gone bad
i have a d16 y7 and my synchros are going out
.Everytime i shift into 3rd gear it grinds. wondering what i need, is it hard to do, wat do i do to change it out?
Modified by T Rick at 10:32 PM 9/10/2006
.Everytime i shift into 3rd gear it grinds. wondering what i need, is it hard to do, wat do i do to change it out?Modified by T Rick at 10:32 PM 9/10/2006
I'd probably check the tranny fluid first. My old tranny grinded every time i shifted to third gear and i found out that i was just low on tranny fluid. However, if the problem persists, i'd recommend a tranny swap. Y7's are relatively cheap and easier to find. Its easier if you know someone who has experience to help u swap it out.
oh i forgot...replacing your synhros are probably going to be more difficult and expensive than swapping trannies
Check your tranny fluid first and foremost. You could be low on mtf. I ran into this problem, and realized that I had a slight leak in my transfer case and only had about 1/2 a quart of fluid in it. It made my 3rd grind like a bad synchro and my 5th pop out of gear every once and a while. I drained what remained and put in 2.3 quarts of GM Synchromesh. Myself and a few of my friends have had fantastic results with it.
Rikaro
10
Jun 6, 2007 04:38 PM
jimboek
17
Apr 26, 2007 03:48 PM
b18cEF9
Jan 12, 2005 05:20 PM
FLCivic
10
Apr 14, 2004 07:19 PM
