B16B HEAD & B18C BLOCK?
Old Apr 29, 2002 | 11:41 AM
g's integ's Avatar
Default B16B HEAD & B18C BLOCK?
Getting b16b head in two weeks along with type R pistons. What power you think I can get from this? Should I put the pistons on as well. Worried about high CP.
Old Apr 29, 2002 | 11:44 AM
Kataku2K3's Avatar
Default Re: B16B HEAD & B18C BLOCK? (g'sinteg)
Overall i would way rather go with the CTR head. It will drop ur compression around 0.2 over the GSR head. If it is the complete head then you got some good cams and an overall better flowing head. The GSR will yield a higher compression tho. If you have a C/R over 12.0:1 run 92+ octane and retard ur ignition timing otherwise you should be fine.
Old Apr 29, 2002 | 11:53 AM
MrFatBooty's Avatar
Which Type-R pistons? USDM ITR, JDM ITR or CTR?
Old Apr 29, 2002 | 11:56 AM
g's integ's Avatar
Default Re: B16B HEAD & B18C BLOCK? (MrFatBooty)
CTR pistons,came w/ the package. Thinking of sellin them.
Old Apr 29, 2002 | 11:57 AM
g's integ's Avatar
Default Re: B16B HEAD & B18C BLOCK? (JDMspecEG6)
Isn't the b16b a CTR?
Old Apr 29, 2002 | 12:50 PM
bojangs's Avatar
New User
yes it is
Old Apr 29, 2002 | 03:18 PM
MrFatBooty's Avatar
According to http://www.c-speedracing.com/howto/c.../compcalc.html B16B head and pistons combined with a B18C block will give you around 11.75:1 CR. Should be safe enough...
Old Apr 29, 2002 | 03:25 PM
g's integ's Avatar
I might sell the pistons.
honkyb18c
28
Sep 17, 2015 06:40 AM
sonny0330
Oct 22, 2007 06:28 PM
drigotegi1234
Aug 5, 2006 10:37 PM
TheOne
Dec 11, 2003 06:19 PM
ITR111
Aug 31, 2001 02:19 PM
