what is a rom burner
Old Sep 10, 2006 | 07:04 PM
dkrex001's Avatar
Default what is a rom burner
Old Sep 10, 2006 | 07:20 PM
Wes V's Avatar
Default Re: what is a rom burner (dkrex001)
First off, a "rom" is a "read only memory" IC chip.
When talking about ECU's, it's the rom that holds the fuel and ignition maps. Or in other words how the ECU tells the engine to work.
If you "chip" an ECU, you normally are adding a different ROM chip. The original chip stays where it is, but is disabled and the ECU is told to read the new chip.
SO; A rom burner is a device that is used to load the data into the new ROM chip. It's called a "burner" due to how older ROM chips actually burnt the data into the chip and they were a one time usage thing. In other words, you couldn't erase them and start over. That's not the case anymore.
(it is more accurate to call them EPROM chips. that's erasable / programable read only memory)
Wes
Old Sep 10, 2006 | 07:25 PM
dkrex001's Avatar
Default Re: what is a rom burner (Wes V)
where can i git a rom burner
Old Sep 10, 2006 | 08:07 PM
FaceTuned's Avatar
ebay has them xenocron/moates. just search google or yahoo.
Old Sep 10, 2006 | 08:52 PM
Wes V's Avatar
Default Re: (jdmhatchness)
I highly recommend Moates.net
Wes
Old Sep 10, 2006 | 10:24 PM
dkrex001's Avatar
Default Re: (Wes V)
is it had to do
Old Sep 11, 2006 | 01:35 AM
Magick211's Avatar
Default Re: (dkrex001)
Burning data onto a eprom is not hard at all.... Editing fuel and ignition maps takes a lil more knowledge
Old Sep 11, 2006 | 05:56 AM
Got_soy's Avatar
go moates, **** is easy as hell
Old Sep 11, 2006 | 08:31 AM
dkrex001's Avatar
what do i need to git to do a p28
Old Sep 11, 2006 | 08:43 AM
Got_soy's Avatar
p 28
chipping kit
Old Sep 11, 2006 | 10:05 AM
Fobtions's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dkrex001 &raquo;</TD></TR><TR><TD CLASS="quote">what do i need to git to do a p28</TD></TR></TABLE>
you will need
28p socket
74hc373 IC
1 1/8th or 1/4 watt 10k ohm resistor
eprom
Old Sep 12, 2006 | 11:03 AM
FaceTuned's Avatar
go to pgmfi.org and go to library and read the section on chipping an ecu it'll show obd0 and obd1 just hang out there and you wont need to ask questions itll say everything you need to know just read trust me reading is your friend.
dohc4life
Oct 14, 2010 08:38 PM
WeB
Engine Management and Tuning
Jan 19, 2010 11:17 AM
seen4ever
Aug 4, 2006 12:06 PM
LsturboCRX
Jun 16, 2005 08:04 AM
