Leftover Type-R Stuff for sale...
1. 1998 Integra and Type-R Mint Helms Service Manual $60
2. New unopened S2000 OilFilter and drain plug gasket. (The best oil filter for DC2's). $7
3. JDM ITR Folding Mirrors CW but need a repaint (scratches in paint). They are currently dis-assembled for painting but can reassemble if required. Comes w/wiring diagram and ALL parts needed to install; extra wire, heat shrink, plugs, relay and door switch. Tested and works perfectly. Direct replacement of USDM with exception of right side mirror. JDM RS mirror is NOT convex. Just snap in your stock one. You can wire the relay to door switch and Aux. output of keyless alarm and fold them by remote. $360
4. '98 OEM ITR oil pan. Bottom dented slightly, you track guys can straighten out pan and spot weld those $15 baffles in and re-paint and save $200 $50
5. Brand New MUGEN High Pressure Rad. Cap. P/N 19045-XGER-0000 Still in package $30
6. '98 USDM Final Drive Gearset '98 ITR (Good cond. swapped out for JDM set). $100
7. '98 Aftermarket OEM Headlight assy's (pass side adj. indicater cut off to clear supercharger I guess, otherwise complete w/bulbs). Lenses MINT! $90
8. ITR rear seatback and bottoms. Mint cond. NO fading on headrest area. $375
9. BRAND NEW ITR keychain sent to me by ACURA N.A. for a customer survey(lifetime guarantee and made in U.S. by Macx). Very rare ITR bling! $25
10. BRAND NEW 2 ea. OEM "spring Bolts for front of cat. w/o springs or self-locking nuts. $6
11.BRAND NEW black leatherette Acura Owners Manual case. Never used. $10
12. Two used and pocket worn working OEM keyless entry/alarm units. $10
<U>All prices incl. shipping in Cont. U.S., PayPal 3% extra, O.B.O. </U>
<U>Pics are below. </U>
http://pg.photos.yahoo.com/ph/...58re2
<U>Vouches:</U>
http://forums.clubrsx.com/itrader.php?u=27965
http://www.k20a.org/forum/showthread.php?t=12223
<U>Vouches:</U>
HuskerHybrid
Apr 20, 2004 03:04 PM
