PART 2!! What is this plug/sensor? where does it got, etc...
Old Sep 10, 2006 | 02:52 PM
6doorsentra's Avatar
Default PART 2!! What is this plug/sensor? where does it got, etc...
There is a tube where I'm guessing a hose goes to... and right next to it is a nipple like sensor. I'm not sure what sensor that one is..
I'm not sure what is supposed to go there.
There are like four wires and two of these type of metal ends/plugs.. they're right behind eachother so you can only see one end..they look like some type of ground wires that should be grounded out..
In this picture this is that wire that the plug tore off and i wasn't sure what kind of plug it was..any ideas? I can find another nipple pllug end if its needs it, or if it needs another type of plug end...( i have an extra spair harness-obd1)
This is a hose under the intake manifold. I'm not sure where this is supposed to be run too..
Here is my obd1 dist thats on the obd2 motor.. how do i wire the spark plug wires to the motor? in what order? the motor goes from the dist to the belts-4 3 2 1
and on the dist from the left side of the black rubber piece is?(going clockwise)
all help is appreciated if you can help me please..i appreciate it very much, thankyou!
Old Sep 10, 2006 | 03:08 PM
Tippyman's Avatar
Default Re: PART 2!! What is this plug/sensor? where does it got, etc... (6doorsentra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 6doorsentra &raquo;</TD></TR><TR><TD CLASS="quote">There is a tube where I'm guessing a hose goes to... and right next to it is a nipple like sensor. I'm not sure what sensor that one is..
That's right above the starter/tranny, right? Ya, there's a coolant hose that goes there and a plug slides over that metal pin. Be very careful not to bend orr break it!
The plug is very "application only" It's small, thin, and slides right over the pin.
Old Sep 10, 2006 | 03:35 PM
ZCcivicBOI's Avatar
ok lol here i go again in the first pic a coolant hose goes on there and the nipple plug next to it remember on the other thread there was a wire that had the end cut off of it? it goes there and in the second picture i not sure what it is but what motor are you running a brown sensor might go there i think its for tempature, and in the third pic that i believe is the thermostat ground put it in one of the 10mm bolts on the thermostat, the 4th picture that hose goes into the oil catch can on the back of the block there should be a pvc valve on the end of it and it should plug into the oil catch can, and on the dizzy i believe its 1,3,4,2 and it goes clockwise and #1 is the plug thats tward the top left of the picture anyone correct me if im wrong...
Old Sep 10, 2006 | 03:47 PM
wiZCo's Avatar
Stouts 'n' Scotch
I think those ground wires ground out by the thermostat housing.
Old Sep 10, 2006 | 05:33 PM
Rywire's Avatar
pic 1 = water temp sensor, and the 1 pin is the temp gauge
2 = fan switch goes there
3= ground that
4 = hose for pcv box
Old Sep 10, 2006 | 07:04 PM
this is a d16y8 from a 99 civic into an 88hf crx obd0
Old Sep 10, 2006 | 07:12 PM
Default Re: (VtecE_rex)
i'm being confused from both my threads..i have a sensor in the first thread where you tell me to run these two wires to my fan switch. i really dont know where it is..is it the one on the head that is the brown sensor?
Old Sep 10, 2006 | 07:26 PM
thenick's Avatar
Default Re: (6doorsentra)
Are you keeping it OBD0? If so why is there an OBDI dist. on the motor?
Old Sep 10, 2006 | 07:28 PM
how can y ou tell its an obd0?
the last picture with the plug wires is not my motor
i want it to be obd1..
Old Sep 10, 2006 | 07:45 PM
thenick's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 6doorsentra &raquo;</TD></TR><TR><TD CLASS="quote">how can y ou tell its an obd0?
.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 6doorsentra &raquo;</TD></TR><TR><TD CLASS="quote">this is a d16y8 from a 99 civic into an 88hf crx obd0</TD></TR></TABLE>
Old Sep 10, 2006 | 08:05 PM
the car is obd0, the harness is obd0 stock...i'm throwin in the motor into it...its converted to obd1
im having trouble with the sensors stated..thats all.
Old Sep 11, 2006 | 04:24 AM
up
jetspeedz
Apr 5, 2018 07:53 AM
eddie7978
Apr 3, 2018 09:31 PM
unclemeat8
Nov 13, 2008 05:21 PM
totsie7944
Apr 16, 2008 06:04 PM
Rene M
Apr 26, 2005 10:18 AM
