gsr swap, iab wiring
i just swapped in a 95 b18c1 in my 93 si using the b18c1 harness. now i'm stuck
at wiring the iab wires. i've searched most of the fourms and most people say just switch the pins on the ecu, a20 to a17 or vice versa. also c-speedracing states: A17 for IAB. The pinout for the IAB can be switched from A20. so im a little confused on how to wire it up. which way is the right way???
