Vehicle Will not Start
Honda Accord 2.3 DX/VP 4dr 5/98 Eng Model F23A5. Vehicke will not start. New Battery, try to start nothing will happend. I check the Starter sylinod with a multimeter and I an getting power to the sylinod every time I turn the key, but when connected nothing happends. I will like to replace the starter but I do not know if there is other item that I must check. Sugestions??
Joe!
Joe!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jemojica98 »</TD></TR><TR><TD CLASS="quote">Honda Accord 2.3 DX/VP 4dr 5/98 Eng Model F23A5. Vehicke will not start. New Battery, try to start nothing will happend. I check the Starter sylinod with a multimeter and I an getting power to the sylinod every time I turn the key, but when connected nothing happends. I will like to replace the starter but I do not know if there is other item that I must check. Sugestions??
Joe!
Since you already checked the circuit to the starter, you can suspect the solenoid (sylinod). You can test it, and replace if bad.
Good luck. You should be okay.
Joe!
</TD></TR></TABLE>Since you already checked the circuit to the starter, you can suspect the solenoid (sylinod). You can test it, and replace if bad.
Benkaraffa75
Dec 18, 2017 12:22 PM
needhondahelp90
Nov 25, 2014 11:46 AM
ILOVEGIRLS
Sep 5, 2003 12:03 AM
