Heat treating paint
Now i did a search but came up with nothing.
I painted my valve cover today, and i have a general idea as to heat treatment for paint so it doesn't chip off.
Are they any specific things i should be aware of? I put the cover in the oven for like 10 min at 200 degrees. Its 500 degree paint so i should be ok.
Thanks guys.
Thanks guys.
Instead of curing it in the oven just taking a 30 minute drive can cure the paint as well.
Even powdercoating chips if it's hit hard enough.
Also, if you're using the hi-temp enamel spray paint, do no touch the cover at least for a good 6 hours after you finish the last coat, if you touch it even if it is dry to the touch, it will smear.
thanks for the imput. Heads off my car right now so driving the car is not an option. Did the oven method and am very very pleased with results. Ill do a right up tonight.
adamisgreat88
17
Jun 8, 2009 02:52 PM
