oem zc hood problem
Old Sep 9, 2006 | 04:57 PM
bonestock91's Avatar
Default oem zc hood problem
so i bought this oem hood the other day
i went to put it on and it fit the hinges fine no problems there.
then i went to put the hood down and it didnt latch so i did adjustments and a new t-bar and then i could drop the hood and it will latch fine.
then i went to pop the hood and it would NOT pop so i have to open my door and stick my hand through the door/fender gap and lift the hood up a little, then go around and pull up the hood with out hitting the lever.
i noticed new scratches from the little spike on the striker assembly on the latch
so it hits the latch then with the force it goes in the hole(haha).
SOmy guess is that it forces it sideways to go in, and the spike is too far forward,a nd i adjusted the striker assembly so its as far back as possible, and the spike is too far forward that pulling the hood popper does absolutley nothing.... i need some help guys. help me pop my hood the right way.
Old Sep 9, 2006 | 05:23 PM
Tippyman's Avatar
You need to space the middle peice out with washers.
Old Sep 9, 2006 | 05:25 PM
middle piece? its all one part...
Old Sep 9, 2006 | 05:35 PM
Deetz's Avatar
Crazy Honda Guy
Just like any hood, you should adjust the height of the latch with a big flathead screwdriver so is opens and closes properly. I'm running a ZC hood, fits 100%
Old Sep 9, 2006 | 05:47 PM
i did it , i tried pretty much every position
Old Sep 9, 2006 | 05:48 PM
408wdy's Avatar
Default Re: (Deetz)
the rod that goes down into the latch.. just bend it backward toward the firewall a little so it wont hit.. DUH
Old Sep 9, 2006 | 05:51 PM
"DUH" ive already done that that the problem right now, its not hitting the lil trigger in the latch "DUH"
Old Sep 9, 2006 | 05:54 PM
Ross 2.0's Avatar
In a Junkyard near you.
just keep adjusting. that's all you can really do
Old Sep 9, 2006 | 05:59 PM
408wdy's Avatar
Default Re: (MooGoCow3)
well i had the same problem and did what i told you.. worked fine. best of luck my dude
Old Sep 10, 2006 | 12:27 AM
Spoon Sports's Avatar
Suit up
Default Re: (Deetz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deetz &raquo;</TD></TR><TR><TD CLASS="quote">Just like any hood, you should adjust the height of the latch with a big flathead screwdriver so is opens and closes properly. I'm running a ZC hood, fits 100%
Rockin the zc look here
hood looks pretty sexy
Old Sep 10, 2006 | 03:53 PM
^you whored my thread, die.
ne ways i made a custom bracket and it works fine now. close thread plz
Old Sep 10, 2006 | 05:04 PM
fourthgenhatchB17's Avatar
Default Re: (bonestock91)
Try opening up/enlarging/slotting the 2 bolt holes on the hood latch (the one thats on the hood itself). That way u can push it back further so it slides nicely into the hole
Edit: Whoops, didnt know u fixed it with a "custom" piece. Post a pic of it.
Sammy Park
Aug 27, 2018 09:00 PM
burnt_clutch
Jan 24, 2007 07:14 PM
lude98SH
Aug 16, 2006 08:28 PM
Qikcivic
15
Feb 4, 2004 06:12 PM
