Clutch setting question :)
Old Sep 9, 2006 | 03:47 PM
philkehn's Avatar
Default Clutch setting question :)
When i push in the pedal to my clutch it releases really early maybe a inch, inch and half and i can change gears in motion is this normal or do i have to tighten or loosen my cable when should the pedal be when the clutch releases is my question
Old Sep 9, 2006 | 03:49 PM
Tippyman's Avatar
Default Re: Clutch setting question :) (philkehn)
You want about an inch of free play before the clutch pedal starts feeling resistance. That's what my gf's dad told me and he's been in the car game for a LONG time.
Old Sep 9, 2006 | 03:52 PM
philkehn's Avatar
So I am just about at the right spot, I was told a long time ago but I spaced what I was told lol. Thanks
Anyone that knows different feel free to reply
Old Sep 9, 2006 | 03:56 PM
Tippyman's Avatar
Default Re: (philkehn)
I think that if you tighten it too much the clutch is always getting worn on, so you want some free play. When I finished my tranny swap and took it out for a test drive, I had it too loose and I had to bury the clutch in the floor just to shift!
Old Sep 9, 2006 | 03:57 PM
philkehn's Avatar
yea thats how mine is and then I tightened it a bunch and thats where I am at now. I was worried about wearing my clutch thats why I came to the H-T
Old Sep 9, 2006 | 04:59 PM
philkehn's Avatar
ok well i tightened it and it seems like the screw gets looser as i use the clutch more, as in I have about a inch and a half free play then a couple blocks later im slamming it to the floor to get it in gear, is this normal or am i just retarded?
Old Sep 9, 2006 | 07:27 PM
HondaHeddie's Avatar
is your nut stripped
if not , is it not seated( just keep resetting it till it settles)
if it keeps f'in up, check your cable
Old Sep 9, 2006 | 07:48 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philkehn &raquo;</TD></TR><TR><TD CLASS="quote">ok well i tightened it and it seems like the screw gets looser as i use the clutch more, as in I have about a inch and a half free play then a couple blocks later im slamming it to the floor to get it in gear, is this normal or am i just retarded?</TD></TR></TABLE>
Mine did that to a certain extent. It was because I had to pull the screw assembly out to tighten it properly, and when it re-seated itself it would be looser cause it was in the right spot. I just kept tightening it a lil bit evry time and it's fine now. but it's only plastic, so the threads may have stripped.
98savage
May 15, 2007 10:23 AM
bonstokLS
11
Mar 20, 2006 04:28 PM
Echo2218
Honda S2000
Apr 9, 2005 07:04 PM
CivicRaping
Mar 24, 2005 04:50 PM
94ls
Sep 29, 2004 08:17 AM
