d15b swap GONE wilD....!, what did i do wrong what am i missing?
Old Sep 9, 2006 | 03:06 PM
4dOoR-Ex's Avatar
Default d15b swap GONE wilD....!, what did i do wrong what am i missing?
it all started in a summer day i woke up and my 91 4 door ex had 220k miles all original parts well taken care of(( expletive THIS LEMME ME GET TO THE PROBLEM)) i went and got my self a d15b swap complete nothing missing then got me a jumper harnnes obd0-obd1 with a p28 ecu.. i pull my motor out..im ther for like 5 min looking at my d16 next to the d15.. expletive it im only gonna use the long block(head bottom block) i take apart my d16 and put all that stuff on my d15 (intake manifol,headers,and one or 2 plugs the d15 did not have) i plug all up on the d15 then i swap the motor.. it turns on but it sounds like **** its sooo bad i would trade the car for a dpfi...i get not check engine light at all..not even wen i turn the ignition on.its sounds like its missing a spark but all sparks are ther...for the dizzy i used the obd0 one..i made my own adapter plate.so it does turn on and the time can be moved too..ground i clean befor i screwd it in to the motor.....so anny help would be great...if any one would like to see pics lemme noe and all post them..
my check light dosent come on...my seat belt light dosent come on and my seat belt dosent move..back anf foward like it did b4....any one ps its a 91 civic sadan ex 1.6 mpfi
Old Sep 9, 2006 | 03:24 PM
4dOoR-Ex's Avatar
Default Re: d15b swap GONE wilD....!, what did i do wrong what am i missing? (4dOoR-Ex)
any one?
Old Sep 9, 2006 | 03:30 PM
Tippyman's Avatar
Maybe you should put all the D15 stuff on the motor like it was meant to have.
Old Sep 9, 2006 | 04:29 PM
EF Sedan Enthusiast's Avatar
Default Re: (Tippyman)
well i agree with tippyman. if you have the ecu and the jumper harness that's all you need. the ex is already mpfi and the only thing you need to change is the driver side motor mount. i had a 90 ex sedan but i love my 88 and have converted it to mpfi and obd1. if you need anymore help pm me or reply if you can't use pm
Old Sep 9, 2006 | 05:28 PM
4dOoR-Ex's Avatar
im just gonna buy a 91 long block and do it over...im not real good with the wires.. plus i always liked obd0 more ...thanx thoo and . jdm_ef3. i love how all does 4 doors look can any one join your crew or its a local thing..
Old Sep 9, 2006 | 05:45 PM
Default Re: (4dOoR-Ex)
you are more then welcome to join the ef sedan squad, just post some pix and a little about your 4g4d. keep me posted on your build!
Old Sep 9, 2006 | 11:54 PM
daidilus's Avatar
uhh did you say that you are used the OBD0 dist with the OBD1 conversion? if you did, you need to use the OBD1 dist that will fix your problem
Old Sep 10, 2006 | 06:02 AM
4dOoR-Ex's Avatar
this is the thing i kept the obd0 set up but what i did is use my obd0 dizzy is ther a way to test a dizzy?i still have my obd1 dizzy with obd0 plugs but it wont start think i did the wires wrong....hate looking at my 4door just ther looks half dead...
Tdaar
Oct 1, 2021 04:46 AM
blaze_125
12
Sep 2, 2009 06:47 PM
tubed-ef
Apr 26, 2007 08:23 PM
MounDoggy
Apr 21, 2004 04:51 PM
